Old 11th July 2006, 11:27 PM   #1
GuyPanico's Avatar
Default Anybody use Zaph's B3S's for home theater?
I've been wanting to build a set of Zaphs B3S speakers for a 6.1 setup. With it's discrete unobtrusive size it is exactly what i'm looking for. The price is perfect as well. I could probably build all 6 speakers for under $200. Has anybody else used these speakers for theater usage?
Old 13th July 2006, 05:02 AM   #2
Sounds good!What are the specifications of the loudspeaker?
Old 13th July 2006, 11:01 AM   #3
GuyPanico's Avatar
http://www.zaphaudio.com/audio-speaker18.html
Old 14th July 2006, 04:39 AM   #4
Your webcite and the soundboxes on show are very beautiful.It is difficult not to be tempted.How long does it cost you to finish them?
Old 14th July 2006, 05:45 PM   #5
owdi is offline owdi  United States
owdi's Avatar
IMO, Zaphs B3S design doesn't get loud enough for HT use.
It could work if you use two drivers per speaker instead of one. Wire the notch filter in series with one of them, and wire the BFC circuit (less resistor) in series with the other. Then wire the two in parallel. The impedance will drop to about 4 ohms in the midbass, but your receiver should handle it.
My definition of "loud enough" is 85db at the listening position with 10db headroom. Assuming your listening position is 2m from the speakers, Zaph's B3S design can manage 74db/watt. The B3S can handle 15wrms, which is just enough to get you to 85db, but leaves no headroom.
Using two drivers gets you 85db with 8 watts, and 6db of headroom.
Just for fun, a pic of my B3S project.
Dan
Old 14th July 2006, 09:12 PM   #6
GuyPanico's Avatar
Would the Aura NS3-193's be a better choice? They wouldn't need a notch filter, just a little BSC.
Old 15th July 2006, 01:49 AM   #7
ruerose is offline ruerose  Canada
The Aura's also won't get loud enough for satisfying HT, unless we are talking computer speaker-type nearfield.
Try one of the small 2-way systems also listed on Zaph's site.
Old 15th July 2006, 01:52 AM   #8
http://www.zaphaudio.com/audio-speaker13.html
Linkage to one in particular
Old 15th July 2006, 09:01 AM   #9
The price goes up to $50 per speaker for parts, but you could look at this project.
http://users.d-web.com/dbrown/db313/db313.htm
Old 16th July 2006, 01:03 PM   #10
GuyPanico's Avatar
In keeping with the small 1-way design, I guess the good old w3-871 is my only viable option? With it's sensativity quadruple that of the Aura or HiVi.
Custom Home Theater Project in New Home, Opinions appreciated. thadman Multi-Way 5 20th November 2008 12:40 AM
Using Car Sub in Home Theater jprac88 Subwoofers 5 1st February 2007 10:53 PM
Home Theater XOtothelight Solid State 10 11th November 2005 02:06 PM
Car amp in home theater? JWFokker Car Audio 4 29th April 2005 01:47 AM
Car amp used in home theater Sepultura Everything Else 1 5th October 2004 08:20 PM
Page generated in 0.10190 seconds (78.00% PHP - 22.00% MySQL) with 10 queries
