Old 11th July 2006, 08:11 PM   #1
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
Default 3db increase by doubling driver count
Sorry for posting a thread about what was probably discussed many times , but i didn't find the explanation.
In many forums , i have read that doubling the driver count increses sensitivity by 3db. But i don't understand this.
For example , if you contiue doubling the driver count to infinity, the sensitivity is approaching infinity as well , right ? But it is impossible to get infinite sound power from , for example , 1W of electrical power ! It would be great if someone could include not too complex equations in the explanation , or a link to it.
Thanks a lot,
Lukas.
Old 11th July 2006, 08:15 PM   #2
Did it Himself
richie00boy's Avatar
I see what you're saying, but infinity is a point that will never be reached, that's the whole idea. 'A bit' below infinity you will have passed the point where 1 watt electrical input produces more than 1 watt acoustic power, but that's not really like a magic perpetual motion machine or anything.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 11th July 2006, 08:23 PM   #3
So , the relationship (doubling driver count and gained sensitivity) is actually non-linear , i.e , i actually gain a bit less than 3 db by doubling speaker count ; even less by quadruppling , and so on.
So i end up with less than 1W of acoustic power for 1W electrical input , regardless how many drivers i add.Right ?
Lukas.
Old 11th July 2006, 08:35 PM   #4
Did it Himself
No, that's not what I said. It's linear.
Old 11th July 2006, 08:42 PM   #5
So , i don't understand this...
For example , we have a driver with sensitivity of 90db/1W.
if we take a billion of drivers , and power them the same 1W(1W for all drivers, 1/(10^9) for one driver).
We get spl = 90+10Log(10^9) = 190db.
190 db SPL is more than 1watt of acoustical power for sure.
Please point where i am wrong.
Lukas.
Old 11th July 2006, 09:02 PM   #6
darkfenriz's Avatar
If you double drivers and connect them in parallel, than voltage sensivity increases, but power sensivity remains the same.
Old 11th July 2006, 09:08 PM   #7
Thanks for reply. I have read a lot of posts in another forum when people try to proove that increasing driver count increases power sensitivity as well, for example , connecting two drivers in series would not affect the SPL , even though 2 drivers are getting 0.5W due to increased impedance.
regards,
Lukas.
Old 11th July 2006, 09:34 PM   #8
Did it Himself
Electrical power input does not need to equate to acoustic power output, they are different things. Energy conversion is taking place.
Old 11th July 2006, 09:41 PM   #9
So , the acoustical power will always be less than electrical due to losses
Old 11th July 2006, 09:48 PM   #10
darkfenriz's Avatar
Of course, much less than electrical because of mechanic-acoustic impedance mismatch. Horn loudspeakers work as acoustic impedance transformers and may reach power efficiency of, say, 80%. Typical drivers have very low power efficiency.
Dual LowSide gate Driver Current Doubling TechGuy Power Supplies 4 17th September 2008 05:49 PM
pin count question gary h Tubes / Valves 7 16th June 2008 09:07 PM
can i increase the impeadance of a driver? larrellio Parts 3 21st July 2006 08:18 AM
way to increase driver sensativity. mp006ltk Multi-Way 9 5th November 2005 05:49 PM
doubling driver numbers/spl gains? RobWells Multi-Way 63 9th December 2002 03:31 AM
Page generated in 0.10704 seconds (77.12% PHP - 22.88% MySQL) with 10 queries
