Hi Guru's, I wondered if I may ask for some advice.
I've done the searches and got myself in a complete daze Nearfiled listening between 1 > 3 metres Speakers to be built-in to a unit against a wall. In front of which is the dining table (listening position). Cabinet depth about 400mm by about 3metres wide so the speaker cabs will be built into the left and righ extremities. Width and Height of speaker cabinets as required but the available space starts @ 900mm from the ground with a seated listening position. Amplifier: Charlize, class D, low power. Type of music: Low volume Jazz, easy listening...the usual dinner/social tunes! Budget?: The cabinets are irrelevant but let's say about £150(ish) on the drivers. Any advice on drivers and sealed or front ported cabinets would be very much appreciated |
#2 |
Did it Himself
Stick a Jordan JX92 in each side, use the reflex design off the Jordan site. I think it's 7 litres.
Trust me, so simple but sooooo good, perfect for what you want.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 | |
Thanks for the passionate insight Sir, obviously one of your favourites. There is an 8 litre reflex and it certainly will fit nicely. Thanks again |
#4 |
Did it Himself
I've just been stunned how good these units are, from an almost non-believer stance.
#5 |
are you using them with subwoofer?
F |
#6 |
I've heard the Jordans in a TL (I think, maybe BR).
Very, nice, very smooth. No big bass, of course, but should be just the ticket for what you want. Easy to listen to - and that's a good thing.
Take the Speaker Voltage Test! |
#7 |
OK then, so these look like a real favourite....any more ideas from the two way department maybe?
Or maybe another fullrange.... I wonder if the lack of toe-in may be an issue though? Just a thought....If I made th efront of the unit with doors then would they all become the front baffle?.. |
| 4th BP experts? | danielm | Subwoofers | 4 | 20th July 2009 04:47 PM |
| DHT experts, i need your help | Cassiel | Tubes / Valves | 10 | 25th February 2009 01:42 PM |
| FET experts advice needed | bostjancek | Solid State | 4 | 24th November 2005 01:52 AM |
| Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice | moving_electron | Chip Amps | 0 | 16th February 2005 12:37 AM |
| Page generated in 0.10309 seconds (78.67% PHP - 21.33% MySQL) with 11 queries |
