Old 10th July 2006, 02:09 PM   #1
e-side is offline e-side  Netherlands
Default Strange Speaker Impedance Curve
I just tried to measure the TS parameters of a loudspeaker. Everything was ok, until I had to measure two frequency points (Fl or F1 and Fh or F2, see http://www.epanorama.net/documents/a...arameters.html) at which a certain calculated impedance had to occur. While finding these, I noticed strange impedance values, so I decided to put these into a graph (see attachment).
The impedance curve of the measured loudspeaker, in free air, has two maximum impedance points, in stead of one at the resonance frequency. I'm sure I followed the measurement instructions correctly.
The driver has 2 voice coils, they were wired in series when I measured. I already did some measurements some time ago, before the drivers were put in a bassreflex enclosure with only one coil connected. They had a quite low Qes and Qts values, around 0.25
Could someone tell me what the cause of this strange impedance curve could be?
regards
Ewin
Old 10th July 2006, 02:18 PM   #2
Possibly you've wired the coils in anti-phase ?
No idea whats this causes (except poor output)
but I assume measured results would be strange.
/sreten.
Old 10th July 2006, 02:43 PM   #3
tinitus is offline tinitus  Europe
could it be because of "copper short rings", I dont know what its called in english
Old 10th July 2006, 03:08 PM   #4
KBK is offline KBK  Canada
The shorting ring would not cause that. The best axiom has always been.."the more difficult the problem to solve..the more basic the mistake." (meaning the root source of the issue at hand is buried in fundamental questions, issues, or 'facts')
I would suggest looking at the whole thing, with fresh eyes, from the start, again.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
"Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti
Old 10th July 2006, 03:09 PM   #5
soongsc is offline soongsc  Taiwan
soongsc's Avatar
The impedance level is so high, I do wonder whether they are connected out of phase or not. Perhaps you'd want to show how the imnpedance measurement is hooked up?
Hear the real thing!
Old 10th July 2006, 03:11 PM   #6
Svante is offline Svante  Sweden
Svante's Avatar
Is the driver mounted in a box or is it in free air? If it is mounted in a BR box the impedance will look similar to what you describe, but typically with a deeper dip between the two peaks.
Is there an extra mass load on the cone (like coins or something for measurement purposes)?
Are there any crossover components still connected to the drive?
What voltage do you use for the measurement, is it possible that the driver is overloaded?
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 10th July 2006, 06:24 PM   #7
I checked the connections several times; I'm sure the speaker was connected correctly. Also, I could feel the cone moving when frequencies were applied. I guess it wouldn't move when the coils were wired in anti-phase...
As follows:
Amplifier +
Old 10th July 2006, 06:57 PM   #8
As follows:
Amp [+]----- (1K resistor) ----- [+]* (VC1) [- ]------[+] (VC 2) [- ]*------- [- ] Amp
* = connected to multimeter
- This curve also made me think of a BR enclosure, but the measurement was taken in free-air.
- I didn't use any mass load.
- I only used a 1 KOhm resistor between the amplifier and the driver, no other crossover components
- The voltage across the calibration resistor (which is substituted for the speaker coils in the circuit above) was equal to it's resistance: Rcr = 8 Ohms and Vcs = 8 mV. I used this voltage level (voltage equal to resistance) in previous measurements, and the results were accurate. Nevertheless, would it be better if I used a higher voltage level?
I'll definitely do that.
Thank you all for your replies.
regards
Erwin
Old 10th July 2006, 09:38 PM   #9
Svante's Avatar
So, your system setup sure sounds alright. There is a slight possibility that the level was too low, with 1mV/ohm, but I would not think so.
Another explanation that came to my mind. Was the driver lying on a table or something that could flex a bit? It might be that the mass of the driver (magnet system and all) and the springiness of the table happened to resonance at somewhere in the range 30-80 Hz. That would give you an impedance somewhat like the bass-reflex box, I think.
Yet another thing: did you test the multimeter reading with the calibration resistor with different frequencies? I might be that the multimeter has a funny frequency response.
Old 10th July 2006, 11:28 PM   #10
soongsc's Avatar
Is the driver ferro fluid dampped?
Impedance Curve jwatts Car Audio 2 2nd December 2004 08:33 AM
Impedance Curve jwatts Multi-Way 4 22nd November 2004 05:45 PM
Impedance curve...... rabbitz Multi-Way 6 4th September 2003 02:52 PM
Help: SS Impedance Curve Jay Multi-Way 4 21st August 2003 07:56 AM
Impedance curve masterp2 Multi-Way 8 3rd March 2002 12:34 PM
Page generated in 0.11585 seconds (83.80% PHP - 16.20% MySQL) with 11 queries
