Hello All,
At this time, I have a pair of MAudio BX5s playing from my PC. The nearfield experience is fantastic for sound, imaging, depth of soundstage, etc. I was wondering, can I expect the same nearfield sound from a pair of home audio speakers? Are they actually made any differently? I simply cannot see how it would make a difference unless there is some built-in delay mechanism to control the timing on powered studio monitors since they are expected to be heard from a close distance. I would try this myself, but I would have to fabricate TRS to RCA cables to do it, and I don't have any extra TRS connectors around right now. Thanks! Paul |
#2 |
i wouldn't expect to have any difference in near field unless there were more than one transducer involved.
then, the lobing involved would have to be designed around near field or to a specific distance within given design characteristics. a single speaker, however, will have sound waves proprigating from its focal point in its unique way and the distance to which it is listened at wouldn't make difference beyond your normal room interactions. just a thought though, i can't see any design characteristics that would be unique to near field as opposed to far field other than room reflections. actually... if you think about it, on near field you might be inclinded to focus more on off axis performance since the majority of the time you wouldn't be sitting perfectly still in the perfect sweet spot, but that can be attributed to both near field and far field. ??? |
#3 |
There is also the issue of baffle step diffraction. This effect is not noticed close up as it is at a distance. Any speaker that was designed to be used away from a wall and has the baffle compensated for, may sound a little bassy close up.
#4 | ||
Thanks guys! Paul |
| Nearfield ribbon? | 8675309 | Planars & Exotics | 5 | 4th August 2007 05:57 AM |
| Nearfield Active Monitors Being Used for Hi Fi Listening | sound_prodigy | Multi-Way | 2 | 30th December 2006 08:55 PM |
| best diy nearfield speakers for <300 shipped | thadman | Multi-Way | 0 | 25th September 2006 10:28 PM |
| Nearfield Stargate | Magnetar | Multi-Way | 18 | 27th July 2005 02:38 PM |
| re: nearfield monitors | jeantofte | Multi-Way | 5 | 12th October 2002 10:27 AM |
| Page generated in 0.08371 seconds (71.86% PHP - 28.14% MySQL) with 10 queries |
