Old 7th July 2006, 03:37 PM   #1
Default best place for ports on bipole?
where is best place to put ports?
on front and back?
just front?
just back?
or at bottom firing down?
they will be a aways from wall a bit cause mid driver is in open baffle.
Thanks!
It is not you... you are it.
Old 7th July 2006, 10:08 PM   #2
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
I am guessing it does not matter as long as the port is one wavelength (of the port tuning) from the driver...but that is just a guess. I am trying to learn more about bipoles myself.
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
Old 7th July 2006, 10:14 PM   #3
FastEddy's Avatar
Default Definately in back
when in front, the driver can "couple" with the horn / vent / port at certain freq.s ... and its like the driver is pushing whole the port is sucking = wasted watts, dead sport in the response curve, etc., etc.
In back the sound pressure has to go clear around to the back of the box to "couple up" and ... at higher mid range, sound just does not travel that way = very little or no coupling.
Old 9th July 2006, 02:15 AM   #4
owdi is offline owdi  United States
owdi's Avatar
IMO, place the port so it's pointing way from the listener, either on the back or the outside of the enclosure. There is more than just bass coming from the port, especially when the woofer covers midrange frequencies.
Dan
2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109? jarthel Parts 12 26th July 2007 09:08 AM
t-amp with fostex 127e bipole or FR125 bipole? alexg Full Range 6 23rd August 2006 07:49 AM
Where to place ports? mazeroth Multi-Way 3 22nd December 2004 03:27 AM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 09:26 AM
curved ports vs. multiple ports Craig Multi-Way 1 22nd September 2002 07:30 AM
Page generated in 0.07164 seconds (70.90% PHP - 29.10% MySQL) with 10 queries
