2 bass speakers on the side
Old 4th July 2006, 06:54 PM   #1
jimbo is offline jimbo  Netherlands
Default 2 bass speakers on the side
Hi guys,
I am planning to use a small full range speaker and two 8" bass speakers on the side of a new vented design. They will be placed back to back (this to keep the front small). What is the best way to connect these guys? Do they need to be connected in phase or not and in parallel or in series? Do you know the advantages or problems with the different methods and what does this mean for the Vb of the box?
What will the loss in loudness be when placing the units on the sides and how about the introduced delay? What is the maximum frequency for the X-over and what order should preferably be implemented in this case?
Any info is more than welcome, because I can't seem to find a lot about this subject.
Thanks in advance!
Old 4th July 2006, 09:41 PM   #2
nunayafb is offline nunayafb  United States
In phase. And series or parallel depending on your amp. If parallel you will halve the impedance, in series you will double the impedance. it depends on the ohm rating of the speaker and ohm capability of the amp.
series/parallel does not affect box size. two side firing woofers will cancel forces on enclosure(in phase)
No loss in loudness until the off axis response of woofers start to drop below on axis response. The delay will be slightly larger than front mounted woofers. The sound will eminate from the voice coil (acoustic center) so just measure the distance from the vc of woofer to the front of the baffle and measure the depth of the full range speaker from baffle to vc (unless given). the difference will be close to the actual delay.
As low as possible, I cant give you an exact frequency but from reading many other posts if you crossover your subwoofers higher than 100hz they will become more localizable. It sounds like you might be using these at higher frequencies though so keep this in mind.
2 bass speakers on the sideHide this!Advertise here!
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 01:28 PM
HT: Side and Rear speakers Brett Multi-Way 45 14th August 2008 11:59 PM
Mounting speakers side by side jamikl Multi-Way 2 6th August 2007 06:01 AM
XXLS low bass - Facing Front, Side, Down or Back DEQ+TheEnd Multi-Way 1 11th November 2006 12:26 PM
speakers from the side of the road troublecomes Multi-Way 4 5th September 2006 10:48 AM
Copyright ©1999-2017 diyAudio
