Old 3rd July 2006, 08:22 PM   #1
Default Any Improvement on WM-60AY capsules?
Okay, I'm finaly going to break down and buy a few Panasonic WM-60AY capsules from Digi-Key, and learn Speaker Workshop.
However, I vaguely remembered that someone said that Panasonic has come out with a better capsule than the WM-60AY. Which one is it? I know about the WM-61A, but that is about the same quality.
If anyone knows of a better, more accurate capsule than these two, please let me know.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 4th July 2006, 01:21 PM   #2
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
The WM-61A is the best one AFAIK. I use that one with the Wallin preamp and standard calibration file with SW.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 4th July 2006, 01:33 PM   #3
AuroraB is online now AuroraB  Norway
AuroraB's Avatar
Does anybody know where to find the drawings for the jig and preamp...??
I downloaded it a long time ago, but probably lost it in a disk crash....
<<< Real men don't do back-ups >>>
Old 4th July 2006, 01:47 PM   #4
infinia is offline infinia  United States
infinia's Avatar
Sadly the WM-60AY is no longer available new, but the WM-61A should work just as well, maybe better.
Link to info on panasonic mic capsules and their modifications(Linkwitz Labs)
http://www.linkwitzlab.com/sys_test.htm#Mic
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 4th July 2006, 02:04 PM   #5
Vikash's Avatar
http://mysite.verizon.net/tammie_eric/ericindex.html
PCB's and kits available here: http://www.madaboutsound.com/prod.asp?pname=MPK
Old 4th July 2006, 04:57 PM   #6
AuroraB's Avatar
Thanks alot'.....
I've been googlin' for this several times, but never found it!
Old 20th July 2006, 04:03 PM   #7
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
Does this same mode apply to the 61A? Anyone done it? It looks like it will be harder - I had some of the 60s but can't seem to find them so I'll use the 61s I have.
If one is using something like the M-Audio Fast Track USB recording device, then you wouldn't need a preamp, I presume? But I would still need to provide power to the mic? Can anyone suggest the best easy way to do this? I'm guessing I need a 9 vold battery, a couple capacitors and a resistor, I've seen lots of schematics around the internet but I'm not sure which one to use with the XLR input on the Fast Track.
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 20th July 2006, 06:46 PM   #8
infinia's Avatar
Originally posted by critofur
Can anyone suggest the best easy way to do this? I'm guessing I need a 9 vold battery, a couple capacitors and a resistor, I've seen lots of schematics around the internet but I'm not sure which one to use with the XLR input on the M-Audio Fast Track.
To modify a WM-61A capsule should be exactly the same as 60A.
The attached image can give you some idea for a schematic to work with the M-Audio preamp XLR input.
Old 21st July 2006, 05:35 AM   #9
critofur's Avatar
Infinia,
Thanks for the schematic. In the center above the arrow that points down then left, it looks like it says 1K but I can't make out the 1st letter/symbol. Then on the left side under where it says WM-61A it's not clear to me what connections are being made. Could you show which wire connects to which pad perhaps? It looks as though you are connecting 3 to the outside of the capsule and to one of the pads, then 2 is connecting to the other pad? I'm assuming then that 2 is the pad which would have been connected to the outside of the capsule before making the mod?
Critofur
Old 21st July 2006, 07:11 AM   #10
Keld is offline Keld  Sweden
Keld's Avatar
Hi
about a jig: look at this: http://www.kensonpro.com/matro/index.htm
Unfurtunally in swedish only, but for those who understand, this is THE place to go.
Electret Microphone Capsules cm961 Parts 12 6th February 2012 10:24 AM
Wanted: microphone capsules, especially Transsound Spasticteapot Swap Meet 1 7th May 2007 04:52 AM
Alternatives to the Panasonic WM-60/61 mic capsules percy Everything Else 0 29th March 2006 03:23 PM
chinese mic capsules rafafredd Parts 3 4th February 2003 04:31 PM
Page generated in 0.09696 seconds (85.83% PHP - 14.17% MySQL) with 11 queries
