I'm VERY tempted to attempt to hack together some new speaks for The Bunker. This long weekend, I'm somewhat messing with a pair of NSB/Neo line arrays, and may actually have them completed before Labor Day...
You know, it takes the same time to cut a 4" hole as it does to cut a 15" hole? Anywho, I've been thinking toward pro-sound drivers... Something on the order of the Eminence alpha 6 or Beta 8 mids (probably two, MTM), a horn tweeter (leaning toward blowing about $50 each on Seleniums...), filling in something of the low end with 12-15" drivers... Speaker height isn't a problem, at least for the mains - if I can flank the screen about halfway up, I'm happy. I'm thinking that I can get away with an MTM each for the surrounds, so that should be cool too... It's the mains that are really giving me fits. I can figure the high end and mids - it's figuring out what to use for something that's relatively cost effective, and will actually play low enough, that's the rub... Then again, I've got a friend with a band who calls a pair of twin 15s "mids." They use a pair of dual Peavey Lowrider 18s for their low end... And actually, their setup doesn't sound half bad, altho they're crossing their tweets a bit high... |
| Q that is too high and other musings... | jaberwocky6669 | Multi-Way | 35 | 9th June 2007 11:34 PM |
| Damper Diode Musings | Eli Duttman | Tubes / Valves | 12 | 21st February 2005 05:08 AM |
| Musings about negative feedback | Circlotron | Everything Else | 49 | 1st February 2005 08:58 AM |
| The transistor age... Musings | Frazzled | Everything Else | 4 | 14th July 2004 04:33 PM |
| Monaural Hi-Fi Musings | mashaffer | Everything Else | 4 | 4th July 2004 06:14 PM |
| Page generated in 0.07101 seconds (65.95% PHP - 34.05% MySQL) with 10 queries |
