Dear all,
I'm new to speaker design. I've just successfully finished designing, building, and fine-tuning a 2-way MTM (with a lot of help from many of you). I've used a Panasonic mic capsule, SW software, an external USB sound module, and my laptop to do the measurement and xo design. I think I "know how to do it now", for Fc higher than, say, 1KHz. But I want to design a 3-way now, and the woofer-mid Fc will be fairly low: maybe 300Hz. At that point, I'm in near-field measurement territory. Therefore, I guess I'll have to splice the nearfield with the farfield SPL curves to get the full curve for both the midrange and the woofer, before I can begin designing the xo. I have a few questions, and I can't seem to get clear answers to them even after having read Claudio Negro's tutorial and getting some clear instructions from some of you:
Incidentally, I don't have any large field or parking lot where I can take gated farfield measurements down to 50Hz or anything like that. I'll have to do it all in my modest-sized living room, hence nearfield measurements are a must, I guess. Please help. PS: In case you are curious, I already have some inexpensive drivers lying around, and I feel they can't be used well in a two-way, and it'll be great to use them to learn how to do a 3-way design, hence this project. So the drivers are a given; please don't suggest "Why do you need a 3-way at all?" The mids will be TB W4-657 drivers, xo'ing at perhaps 3KHz to a local fabric dome tweeter made by Peerless India. The woofer will be some unknown 8" aluminium-cone driver with a huge magnet, cast frame, fat rubber surround and (presumably) huge Xmax, which I picked up from the local market. It's apparently made by a company called "Alda". I'm hoping that I'll be able to xo these Alda 8-inchers at something like 300-500Hz to the W4-657s without too much cone breakup problems with that Al cone. |
#2 |
Can anybody please help?
Is it that my questions don't make sense? |
#3 | |||
First off patience, we all know what its like to hit a stopping point and have to wait for some replies to our questions, its a part of the hobby, for noobs anyway. In addition, some posts take a couple of days for an educated response, not everyone checks here daily.
All right to the Q's: Quote:
Gotta run, hope someone else answers the rest of your questions soon. |
#4 | ||
If you want more info, you could go from gated, to pink noise, to swept sine testing to include reflection and standing wave information respectively, then trawl throught the plots and smooth them by hand using best judgement. While tweaking, I find it useful to connect my mike (at the listening position) to a spectrum analyser (computer based) and play pink noise, changing crossover values whilst watching the screen. |
#5 | ||||||
Alternately, can I design the woofer-to-mid xo by just working on the (spliced) SPL curves, and ignore the phase issue altogether. Would that result in phase-accurate xo? (I'd guess not, because the Fc could be as high as 200-400Hz, where phase would, I'm sure, be very important.) Quote:
So, based on the answers and some of my own newbie thinking, I'm wondering whether the following will work:
Will this work? Can I design the xo with these two graphs? Quote:
![]() Thanks a lot, Tarun |
#6 |
I have a refinement to what I suggested earlier.
Will this work? |
#7 | |||
One reason is that the near field plots become invalid at higher frequencies, and another reason is that diffraction effects may contribute phase information that is needed. Quote:
If you want to do this, you'll need to set the analyser to wide band. Third octave spectrum analysis is an excellent tweaking tool, but I use between twelfth octave and full octave analysis as I find each step seems more useful in dealing with specific problems. For example (broadly speaking), full octave is more useful for tonal balance issues. Third/sixth is useful for crossover issues as it gives more data but ignores the high Q peaks/troughs. Twelfth octave is useful for finding resonances. EDIT: Just noticed your second post. |
#8 |
Hi all,
Tcpip I would suggest you to calculate minimum phase from the driver's frequency response using FR Combiner, and then use the resulted curves (spl+phase) for crossover simulation. I describe this procedure in my home page (folder SW Phase). In short: 1) place mic on mid axis and measure woofer and mid (far field). 2) measure NF of each driver and splice it with the far field. 3) Try to use the higher sample rate your card supports. 4) Use FR Combiner to calculate the driver's minimum phase and export the resulting curve. 5) Import the curve in the simulation software. You can also try the Ralph's technique, if you like, always using the calculated minimum phase curves: I descibe it in my Home Page (folder SW Acoust. Measure/Far Field/Gated). Regards, Claudio |
#9 | |
One more question: do I need to worry about baffle diffraction and apply BDS before I use FRC? Thanks a lot. |
#10 | |
Regards, Claudio |
| How do Dayton, Vifa, MCM measure drivers? | diesel_88 | Multi-Way | 2 | 7th August 2008 04:15 AM |
| How do you measure drivers, what works/doesn't work | pjpoes | Multi-Way | 5 | 20th July 2008 04:45 AM |
| Equipment to measure amplifiers design | samsagaz | Parts | 2 | 22nd June 2008 08:06 PM |
| Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? | percy | Multi-Way | 0 | 12th March 2006 09:18 PM |
| design help: box=20L, ... drivers=? | zobsky | Multi-Way | 6 | 18th September 2003 04:27 PM |
| Page generated in 0.17042 seconds (87.66% PHP - 12.34% MySQL) with 10 queries |
