Old 2nd July 2006, 10:19 AM   #1
Scottmoose's Avatar
Default Seas Froy TL
Only a quick idea, this, but I don't think it's been suggested before. I was fooling around in MathCad earlier, using the Seas Froy midbass drivers as a basis, when it occured to me to look what would happen if someone tried these drivers in the Thor enclosure. Thor doesn't really have enough Vb to do its larger drivers justice, but the smaller Froy units look like just the ticket. It's a bit wider than the original box, but I doubt it'd cause too much of a problem with baffle-step.
So, 1 standard Thor enclosure, with 0.5lbs ft^3 of stuffing, except in the last 9in of the line, and the 2 Seas Excel W15CY001 midbass units used in Froy. The SPL might be a bit off, as I don't know what the crossover will do (I haven't seen it), but the curve will be right. If you have a Froy, fancy a traditional TL and like trying stuff out, this could be fun experimental project. Shouldn't cost much either as it's a simple build -a couple of sheets of MDF, glue, 4 binding posts, a bit of wire and some pillow stuffing. About £50 all in.
Just a bit of fun really. But could be interesting.
Best
Scott
Old 2nd July 2006, 10:46 AM   #2
Cool !.......so how about the same idea with the ODIN
2 x W17E002 and 1 x T25001 in MTM arrangement. Original Baffle was 230mm ( 9 of those imperial thingos )
Old 2nd July 2006, 12:10 PM   #3
Scottmoose's Avatar
The current Odin MK3 uses the exact same drivers and crossover as Thor -the W18E001. The W17 should work though. Again, just make sure you don't stuff the last 9in of the line. I'm waiting for a current Thor owner to try that out and tell me what happens to confirm a growing suspicion. I can't say any more on that subject just yet though.
Scott
Seas 27TDFC H1189 vs Seas 27TFFC H881 ermes Multi-Way 4 19th April 2011 01:20 PM
Wanted: Seas W17EX001, Usher 8945P, Seas CA18, or somewhat similar mid-woofer. Spasticteapot Swap Meet 2 7th March 2007 04:06 PM
Any Froy or Odin owners? weinstro Multi-Way 19 4th March 2006 09:33 PM
Seas Excel W26 compaired to Seas L26 (10") harruharru Subwoofers 9 11th March 2005 09:47 PM
Froy Mk3 w/Dayton RS? MisterDuck Multi-Way 3 29th November 2004 06:56 AM
Page generated in 0.07426 seconds (71.19% PHP - 28.81% MySQL) with 11 queries
