Old 3rd July 2006, 02:52 AM   #11
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Dickason's LDC 6th edition.
See fig 7.20 B on how upward tilt works with ZDR
Section 7.23 Page 112 explains
Page 114 2nd last para explains the inverted woofer "Experts often.... blah blah".
Dickason also adds "radiating centre may be assumed to be the centre of the voice coil".
Horizontal or Hd (on my pic) if 0 has no delay but as the Hd increases then there is a delay between the woofer and tweeter due to the horizontal difference. So if a tweeter is on top and the woofer below, the sound from the woofer is delayed hence the polar downward tilt, for the inverted it's an upward tilt.
1st orders are sensitive to horizontal offest of drivers and to function correctly need to be time aligned so Hd=0.
Read LDC section 7.23 as it explains it better than I ever could.
No longer DIY active
Parallel or serial notch filter in a crossover? Jonasa Multi-Way 12 3rd May 2012 10:54 PM
time alignment on passive crossover? Ken L Multi-Way 13 7th November 2009 12:52 PM
excel sheet for TL allignment Henkjan Full Range 0 4th March 2009 07:47 PM
crossover first time builder. Dannyball Multi-Way 20 1st February 2005 08:51 PM
Need Laser allignment tips phillips dvd622 Ben Digital Source 0 25th February 2003 12:28 AM
Page generated in 0.08793 seconds (56.86% PHP - 43.14% MySQL) with 11 queries
