Old 29th June 2006, 06:04 AM   #1
Default strange measurements
Bouyed by the succesful measurement of the TS parameters on my 15" MI speaker I took a shot at one of the RS 5" whizzer drivers (looks like a fostex with the tan cone and brown surround) and got very strange readings. When measuring the voltage across the resistor (in series with the driver) instead of getting a null indicating Fs the voltage just kept dropping gradually all the way from over 300Hz down to 30Hz. Now I know this thing doesn't have an Fs that low and I was able to measure the Fs of 45 on the MI speaker so...
Any ideas what might be going on? In both cases the speaker was suspended horizontally between two wooden chairs. Thinking that it might be interference from the chairs (which are of course proportionally closer to the cone) but holding it suspended vertically didn't seem to make any difference. Could it just be that the light weight speaker needs to be clamped in position?
mike
Old 29th June 2006, 06:51 AM   #2
Ouroboros's Avatar
If the voice coil has a fairly high inductance then you might expect the impedance of the drive unit to increase as the frequency increases. Surely even on a 5" unit the Fs will be well below 300Hz? I would normally expect to see a low impedance at very low frequencies, rising to a fairly well defined peak at the fundamental resonance (the sharpness of the peak being a function of Qes), then dropping untill the inductance of the voice coil causes a gradual rise with frequency.
first THD measurements Pierre Class D 17 7th June 2005 07:18 PM
different measurements resident Tubes / Valves 4 17th April 2005 09:04 PM
anyone have measurements of TB 871? morbo Multi-Way 5 27th November 2004 03:10 AM
Brazil, and some strange laws, not too much strange! destroyer X Everything Else 0 11th September 2004 12:38 PM
GC Measurements lgreen Chip Amps 26 31st July 2004 09:02 PM
Page generated in 0.05787 seconds (80.29% PHP - 19.71% MySQL) with 10 queries
