Old 28th June 2006, 09:46 PM   #1
jaykick is offline jaykick  United States
Default Aluminum faced cabinets?
I'm currently putting together an entire tube system. The chassis are going to be anodized machined aluminum, so it would look nice to have anodized aluminum speaker cabinets.
I figured I'll build them out of MDF, and use lots of JB Weld to glue the sheets of aluminum to the surface. Would having this metal on the surface cause any achoustical problems?
I haven't decided on a design yet, but it will probably be a full range bass reflex. The amps are 300B mono blocks.
thanks,
Jay
Old 28th June 2006, 09:49 PM   #2
Scottmoose's Avatar
Probably not, so long as you make sure the drive units have thin gasket strips to prevent too much contact and vibration. In fact, quite the reverse; should add a touch of the constrained layer effect, and help to damp the enclosure if anything. Celestion's Aerolam cabinets are still very well regarded.
Painting aluminum CarlyBoy Parts 15 14th January 2007 08:35 PM
What For Selenium?-I am faced with a dilemma ZuMbAiU Multi-Way 5 3rd February 2006 07:05 PM
Can someone cut some aluminum for me? DC Dave Everything Else 0 15th January 2006 07:30 PM
How do I get my aluminum to look like this? amo Parts 22 29th July 2004 07:40 PM
Page generated in 0.07410 seconds (74.03% PHP - 25.97% MySQL) with 10 queries
