Hi !!!
I'm here to ask you experts, how should I build the 10BR60's enclosure ! My objective is achieve a very smooth and tight mid and bass, but also clear! I can make use easily of 55L, but it can be less if it's better. The dataheet of 10BR60 shows a response graph with a "Bass6Pro" cabinet, that consists in a 40L, Fb38Hz, bass reflex. There's no other information. THIS is the datasheet take a look please ! Thank you very much ! ![]()
#2 |
urrgg.. I said the 12LX60
..well if it MUST be the 10BR60.. to get a fairly flat in-room response to about 24Hz will require: a box volume of around 3.3 cubic feet and a vent around 8 cm in diameter and 16.5 cm in length
perspective is everything |
#3 |
Vb=50 L
Fb=41.5 Hz Dt=100 mm Lt=190 mm |
#4 |
Humm, what means FB, DT and LT ?
FB of the 40 liter box in the datasheet was 38Hz Thankss !!! |
#5 |
Fb - tuning frequency of bass-reflex
Dt - equivalent diametar of bass-reflex tunel Lt - lenght of bass-reflex tunel |
#6 |
AHm, but the 40liters was 38Hz of FB, 50 liters should be tunned for lower frequency, shouldn't!?
Diameter is like this or that!? Sorry about the fool question ! ANother thing, I'll fill inside the box with cotton or something like that, should I discount in liters it's amount? Cheers ! |
#7 | |||
| Fostex FE107E Double Bass Reflex Enclosure | RemoGaggi | Multi-Way | 1 | 9th January 2009 01:25 PM |
| Fostex FE207E bass reflex enclosure | Thomas B | Full Range | 9 | 29th January 2008 12:23 AM |
| Beyma 10BR60 for OB? | DarkOne | Multi-Way | 0 | 30th October 2007 11:03 AM |
| Bass Reflex Enclosure & Port Tuning | D_GR8_1 | Multi-Way | 2 | 2nd December 2004 10:11 PM |
| Bass reflex enclosure | Opie | Subwoofers | 5 | 5th January 2002 02:36 AM |
| Page generated in 0.09615 seconds (75.76% PHP - 24.24% MySQL) with 11 queries |
