Does anyone have a good source of info on constant voltage impedance measurements. I've always used the constant current method, but would like to try constant voltage. Any links or schematics would be most helpful.
G.
If you take something apart and put it back together again enough times, eventually you will have two of them. |
#2 |
Did it Himself
If you are prepared to offer a bit of feedback, email me your email address and I will send you a document I have written.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
#4 |
Why do you find that interesting?
IMO there is no difference between the two (if I understand what you mean correctly) possibly apart from noise sensitivity (which normally isn't an issue). |
#5 | |
Well...I'm interested in adding some drivers to LEAP using their LTD model which requires that the drivers be measured with a constant voltage rather than constant current (you need a voltage curve and an impedance curve). G.
#6 | |
#7 |
See d'Appolito's book. No real difference between constant current, constant voltage or constant resistance as long as the domain remains small signals.
#8 | |
| Constant Voltage System | redback | Everything Else | 8 | 13th February 2006 04:40 AM |
| Constant impedance relay-resistor logarithmic attenuator | x-pro | Pass Labs | 75 | 27th June 2005 12:12 PM |
| Constant input impedance polarity switcher | Steven | Solid State | 13 | 15th October 2003 02:16 AM |
| T-link attenuator with constant impedance | peranders | Parts | 4 | 7th October 2003 01:19 PM |
| Impedance measurement | Doug | Everything Else | 2 | 9th August 2003 05:50 AM |
| Page generated in 0.10983 seconds (76.16% PHP - 23.84% MySQL) with 10 queries |
