Old 25th June 2006, 05:25 AM   #1
Default SS 18W8535-00 questions
Can someone explain to me the differences between software calcs and real world usage of this driver.
for example :
DIY Proac 2.5 has ~38L volume with 75mm x 140mm port , which
seems to be tuned to around 42Hz , this gives a large bump in the bass response.
Another design has volume of 30L and 62mm x 190mm port , tuned to around 35Hz....bit smaller bump in bass response.
If I stick the T/S parameters into WinISD it comes up with dimensions of 59L with 75mm x 233mm port tuned to 27Hz.....with no bump in bass response.....
Why the large differences / discrepancies ? Which is better or ideal ?
Any help appreciated.
Andrew
Old 25th June 2006, 05:46 AM   #2
I have confirmed by measurements that the 18W/8535-00 in a 38L vented box with 200g/m^2 density Dacron stuffing material on all walls except the front (as per www.geocities.com/diyproac25 directions) gives a port tuning of 38Hz. And IIRC, based on my own computer simulations, there is a mild bass boost of about 3dB, centred at 50Hz.
As for different box sizes and tuning, yes the software is always a little different to the actual. You may find that even different software will give you different results!
I have found that Unibox gives me the most reliable approximations.
Obviously the best way is to measure actual port tuning after building it, and shorten/length to taste.
According to Troels Gravesen, who has probably spent more time with this driver than anyone else in DIY-land, you can kill two birds with one stone using a smaller box and lower port tuning for a more controlled bass response.
I'd go with 25-28L tuned to 28-30Hz, however what is "best" is usually a personal preference, and largely depends on the speaker placement relative to the rear and side walls.
Old 25th June 2006, 11:40 AM   #3
Notax is offline Notax  Montenegro
Notax's Avatar
Default Re: SS 18W8535-00 questions
for example :
Andrew
You can look at this tread, and continue there.
calcualtions
Old 25th June 2006, 11:52 AM   #4
Notax's Avatar
Like you can see in that tread I have some corrections of calculatiuons with Thiel/Small parameters. In this case, with that corrections I got:
Vb=31 L
Fb=34 Hz
Dt=53 mm
Lt=145 mm
Its with catalog values. For the real and exact, unit must be measured, and then all calculate with measured T/S.
Old 25th June 2006, 04:22 PM   #5
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
A pseudo BSC method which can be very effective and I used a similar tuning (40Hz) with a 18W8531G00 and made a huge difference to the tonal balance.
I found a flat response sounds.... er... flat in the bottom end and needs BSC in the filter network or the hump in the bass.
No longer DIY active
Old 26th June 2006, 10:35 AM   #6
IMHO, it's just a form of BASS BOOST, pure and simple.
You can argue til the cows come home where it's a good or bad thing.
Old 26th June 2006, 11:52 AM   #7
rabbitz's Avatar
Who's arguing?
Old 27th June 2006, 09:34 AM   #8
Thanks Gents,
Got an idea whats going on now.
I also discovered that the port length from s/w calcs is too long - need to mult. it by ~0.7 to get the real length........
so correct me if I'm wrong....
the 18W/8531G-00 should go in a 28-33 L box not 40L , and be tuned to ~33Hz....not 31
Old 27th June 2006, 11:21 AM   #9
Notax's Avatar
Thanks Gents,
You are wrong. Simulation are correct for relation between Vb, Fb, Dt and Lt, but are not in every case exact and usefull for Vb.
Old 27th June 2006, 12:09 PM   #10
rabbitz's Avatar
Here's some suggested box sizes and tuning from Scan Speak on the 18W8535-00 (as supplied to resellers and I haven't tried or modelled any of these).
Vb=47 litres
2"x6" port
F3=32Hz
Alt
Vb=53 litres
2"x5" port
F3=29Hz
FIY, the suggested box size for the 18W8531G00 is between 37-45 litres.
scan-speak 18w8535 / D2010/8513 and more budwiser Swap Meet 7 30th March 2009 04:06 PM
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 09:26 AM
BOZ, A few questions? Rip Pass Labs 3 12th November 2002 11:07 PM
Questions, questions, from newb DIYer Phatman91624 Multi-Way 41 3rd August 2002 02:52 AM
Page generated in 0.11041 seconds (79.15% PHP - 20.85% MySQL) with 10 queries
