Hi, i have a question for Speakerworkshop users.
I started calibrating the Wallin jig and get the correct sine wave inputs on left and right channels with a bit of latency. The strange thing is that when i set the test signal for loop record and remove all cables from the soundcard i still get the same inputsignal on both channels. This obviously means that there is no signal going through the jig,but where is the signal coming from? There is no cd player connected to the soundcard. any suggestions kro5998 |
#2 |
it sounds like you have the wrong input selected in volume controls
#3 |
Thanks i found it. I was using the mic. input on the card.The right volume controls though.When i don,t connect an input i still get those signals on left and right channel.When i connect line in everything seems to work fine.
Kro5998 |
| FFT size in SpeakerWorkshop | jm_kzo | Multi-Way | 2 | 9th July 2008 07:48 AM |
| SpeakerWorkshop MLS measurement?? | kimschips | Multi-Way | 3 | 21st June 2006 05:04 AM |
| SpeakerWorkshop again | Dave Jones | Multi-Way | 19 | 17th June 2004 05:34 PM |
| speakerworkshop, meaning of L1 and R1? | capslock | Multi-Way | 9 | 5th June 2003 07:55 AM |
| Speakerworkshop 1.06 soundcard problem | capslock | Multi-Way | 8 | 6th November 2002 11:34 PM |
| Page generated in 0.06571 seconds (69.88% PHP - 30.12% MySQL) with 10 queries |
