Room acoustic
Room acoustic
Old 23rd June 2006, 08:47 AM   #1
cominup is offline cominup  Viet Nam
Send a message via Yahoo to cominup
Default Room acoustic
Dear all,
Now, I get a room (WxLxH) (3.1x3.5x3)m or (10.33x11.65x9.84)ft. It's so hard to listen to in this room.
Do u hav any suggestion of room acoustic? And I hav not found out some where in our 4rum talking about this matter. Do u know where it is?
Cominup
Ill do it by myself
Old 23rd June 2006, 09:41 AM   #2
Geek is offline Geek
Geek's Avatar
Hello,
Hard to listen.... why?
Too boomy? Too flat?
Old 23rd June 2006, 09:43 AM   #3
Tenson is offline Tenson  United Kingdom
Since this is the loudspeaker forum I would make the suggestion that you choose a speaker which will work well in that room. An open-baffle maybe? Placed close to corners they will not excite room modes as much as a box speaker. You do need to control the midrange and high frequency reflections though.
Old 23rd June 2006, 09:20 PM   #4
nunayafb is offline nunayafb  United States
cominup, I am in a similar situation although my room is a tad wider and longer. the speakers im building to deal with this room are both waveguided(front and rear) and dipole. the benefit to waveguiding is to "focus" the sound more forward and less sideways and dipole systems tend to have a null or a quiet spot 90 degrees off axis which minimizes room modes. This is a fairly difficult project though and i dont know where you are at in terms of knowledge and skill. Anyways the point of all that was to illustrate that different speaker types are beneficial in certaing listening environments.
To answer the question you asked, try searching for:
room treatments
bass traps
room acoustics
room reflections
those keywords will bring up enough articles to get you started and enable you to ask more specific questions to achieve your goal.
Also, tell us a little more about your speakers, music type, movies?, do you have issues with neighbors/family/roommates who would prefer not to hear your music? Do you have Eq, what kind of amps etc...
Old 24th June 2006, 03:48 AM   #5
Dr.Faustus is offline Dr.Faustus  United States
Ouch!
Your room is very close to square, which makes for difficult or poor acoustics (as you already know). Those nearly square dimensions mean that the room modes (natural resonant frequencies determined by the distance between opposite walls) for width, length and height are very close together. When you have multiple room modes that are very close to one another you will get exaggerated peaks and dips in the room's frequency response.
The simplest answer is to pick a different room with room dimensions (h*w*l) that are not similar or multiples of each other.
If you can't use another room, that's when you need to start looking into modifying the room to improve its acoustics. Start with a room acoustics calculator like this one: http://www.ultimateavmag.com/news/10388/
According to this calculator the problem frequencies for your room are: 57.4, 114.7, 172.1, 229.4, 286.8 and 290.7 Hz.
I expect that you have a BIG problem around 290 Hz as two of the "problem frequencies" are within 4Hz of each other.
The next task is to buy the "Master Handbook of Acoustics" by F. Alton Everest. This is an invaluable resource that is filled with useful information. I suggest that you buy the Master Handbook of Acoustics as it is a necessary resource and you will often want to re-read sections.
Here is a page with a few more links to get you started: http://www.epanorama.net/links/audioacoustics.html This will get you started, as room acoustics is a large subject. You have a lot of reading to do!
Please know that for almost every commercial acoustic treatment product that is sold, there is a DIY solution that will be as effective and often for much less money.
FWIW,
Dr.Faustus
Old 24th June 2006, 03:48 AM   #6
F1 FAN is offline F1 FAN  Canada
Hi you might find some helpful info here. http://www.avsforum.com/avs-vb/showt...2&page=3&pp=30 and here http://www.audioasylum.com/forums/rives/bbs.html
Old 28th June 2006, 01:49 AM   #7
Thank you all,
Shareing with your hobby, I really wanna building up a place to make a open environment in a limited room.
Now, I'm using a pair of JBL LE14A and Altec 811 horn and 802 driver. CDP: TEAC 10SE and powered by some different kind of tube amp. I often listen to Jazz, Blue, Classic and sometimes The Door, Led Zeppline or Jimmy Hendrix. So, I can not have any sound of music in this room.
This one just be used for listening only, so, I can not change and no-one can disturb me.
Yes, I'm thinking about bass traps, diffuser, absorber... But, one thing is WHAT the rate to mix them together and HOW to make them like room decoration.
But, first of all, build a acoustic room is goal rite now.
Once again, thank you very much for all your information and link.
Ill do it by myself
Old 28th June 2006, 02:36 AM   #8
MBK is offline MBK  Singapore
You might want to read this article on loudspeaker positioning and room acoustics . In brief, you do want some room effects, because they are necessary for realistic sound in the bass. Square dimensions are worst though. Possible solution is asymmetric placement, if the dimensions cannot be changed. All this applies even without room treatments. And
this article here is specifically on loudspeakers in small rooms.
Best of luck!
Old 28th June 2006, 03:00 AM   #9
ralphs99 is offline ralphs99  Australia
ralphs99's Avatar
I can agree that both the articles suggested by MBK are essential reading.
It's worth going through all of Floyd Tooles articles on room acoustic in detail. There's a wealth of information, and they're available for free on Harman's web site.
David Griesinger's articles are also invaluable, not only those dealing with loudspeakers, but also his series on psycho-acoustics and recording techniques.
I have also put together a summary of some of the ideas of these authors and some easy to read general information on room acoustics on my new web site. http://www.aeronet.com.au/Acoustics.htm
Cheers, Ralph
Aeronet research pages
Acoustic, Electronic & Speaker Design
Old 30th June 2006, 02:44 AM   #10
Dear all,
Hereafter is a very cool site, isnt it?
http://www.mhsoft.nl/Helmholtzabsorber.asp
Ill do it by myself
Room acousticHide this!Advertise here!
The rendition room acoustic doesn't matter... syntheticwave Everything Else 2 17th March 2008 08:35 AM
How should I acoustic my room??? bluenotes Everything Else 0 12th November 2005 07:07 AM
2" rigid high density fiberglass for acoustic room treatments? darkmoebius Everything Else 6 6th May 2005 08:44 PM
room acoustic sma Multi-Way 0 22nd January 2005 09:41 AM
room query/ acoustic panels RobWells Multi-Way 2 15th April 2004 06:09 AM
