Advice on 2 way system
Old 22nd June 2006, 05:55 PM   #1
MellowTone is offline MellowTone  Australia
MellowTone's Avatar
Default Advice on 2 way system
Hi, I'm planning to build a 2 way speaker system to upgrade from the old Hitachi speakers I have now. I want to make a good sounding system on a rather tight budget (~AUD$250). I want to make one with crisp highs and an Fs of less than 60Hz. The attached file has all the info on it. I have used a design program called Blaubox to design it. I am looking at a RedBack 8" woofer (http://www.altronics.com.au/index.as...=item&id=C3088) and a Vifa VF020A (http://www.speakerbits.com.au/net/ca...aspx?ID=VF020A). I have already purchased the tweeter. In other's experiences, is a 2 way system using an 8 inch woofer powerful enough? I have not seen reviews or anything for these drivers but they look like they are good quality. What do you think of the design? I listen to mostly Metal/Rock/Jazz music. Much Thanks, Nic.
I Reject Your Reality And Substitute My Own
- Adam Savage, Mythbuster
Old 22nd June 2006, 06:50 PM   #2
Nanook is offline Nanook  Canada
Nanook's Avatar
Default 2 way system..
ok, so I think in CDN$... so 20% less, about $200 cdn or $185 USD hmmm.
so you have already purchased the tweeters..so does your budget reflect what you can spend after the tweeters or before?
Those drivers will cost ya $120 AUD.. now some cross overs..and enclosures. What are you using for enclosures?, Can you build or are you salvaging existing enclosures? Can they be floorstanders? Bookshelfs? Sealed? Ported, etc, etc..
You don't or haven't qualified your expectations exactly, and without a design in mind, why did you buy the tweeters?(on sale is plenty good enough reason)
It would seem mathching the tweeter tp a Vifa mid/bass would make perfect sense.
What is the rest of your equipment like , tubes?old ss? new digital?
I would try to emulate something already designed....as a start.
OOPs, you must have added the image after I wrote this or started to respond..
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 22nd June 2006, 07:27 PM   #3
Nanook's Avatar
Why not follow the recommended enclosure and tuning of 15 litres, 50X188 mm port? tuned to 42 ?-3dB will occur at 53Hz or so..using this the -3dB is the same, but the roll off is less steep, and there is a 1-2dB hump between 70 and 100Hz, for a little added "slam"
Old 22nd June 2006, 09:05 PM   #4
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Have a look at this speaker as it may help with your design. It's the one used in the Wiki.
No longer DIY active
Old 22nd June 2006, 10:00 PM   #5
Nanook's Avatar
Default rabbitz..
nice project and certainly applicable (I think) to your country man's needs.
Old 22nd June 2006, 10:09 PM   #6
rabbitz's Avatar
Thanks.... it's a good starting point to spring from.
Old 23rd June 2006, 06:07 AM   #7
scudinc is offline scudinc  United States
The crossover point (3500Hz) seems high considering the 8" driver you're using.
Old 23rd June 2006, 02:21 PM   #8
rabbitz's Avatar
His crossover point is going to be governed by the TC20TD tweeter that he already has bought. With an Fs of 1400Hz it needs to be crossed over about 4000Hz but could go lower with higher orders.
The trick is to find a woofer to match and extend to that point and then rolls off cleanly.... plenty around but a bit high for most 8" mid woofers.
Advice on 2 way systemHide this!Advertise here!
Advice on a new pa system sbattersby 115 PA Systems 14 14th September 2016 09:49 PM
Chip Amp system - need some advice rochmndx Chip Amps 2 12th February 2008 12:50 AM
Computer system -need advice BMD Multi-Way 1 5th March 2006 12:36 PM
Building a new HT system, need advice Mr Pookie Multi-Way 4 11th January 2005 08:21 AM
Advice on upgrading my car system. Mendis Solid State 3 14th February 2003 11:27 PM
