Old 22nd June 2006, 02:32 PM   #1
tubee is offline tubee  Netherlands
tubee's Avatar
Default Round radiating tweeter, aka "Enterprise 1" tweeter!
Hi all.
I want to show here my 2 surround-back speakers. Wanted to keep the costs low, so made for a 20mm CRB-40 neodymium car tweeter a dispersion cone. Woofer is an old bextrene Audax unit.
Daisy Bell
Old 22nd June 2006, 02:38 PM   #2
tubee's Avatar
close up tweeter, sorry for blurryness
Daisy Bell
Old 22nd June 2006, 02:41 PM   #3
tubee's Avatar
Turn in mind picture 180 degrees: Enterprise!
Btw sound is very good for such a cheap tweeter. Removing metal grid before dome was the best modification. Because round radiating highs its like the tweeters can communicate with eachother, very good soundstage in treble. You can walk around the speaker and hear no difference in treble output.
Daisy Bell
Old 22nd June 2006, 03:24 PM   #4
sdclc126's Avatar
Did you make the dispersion cones yourself? What are they made out of?
Nice work BTW.
Soft Dome
Old 22nd June 2006, 04:17 PM   #5
tubee's Avatar
Sdcls126: Made the cones from acrylic (PMMA), turned on a lathe, then polished. The foot is regular MDF silver sprayed, the stander is from alumium. Thanks for compliment
Daisy Bell
Old 22nd June 2006, 04:28 PM   #6
tade is offline tade  United States
Send a message via AIM to tade
I am very impressed! Bravo!
Old 22nd June 2006, 06:44 PM   #7
the cabinets are extremely beautiful, great work man
Old 22nd June 2006, 07:12 PM   #8
Tenson is offline Tenson  United Kingdom
Wow, beautiful!
I wonder why we don't see any omni stand-mounts?
Old 22nd June 2006, 07:18 PM   #9
tubee's Avatar
Thanks Nemophile, Tade.
Cabinet is simple: MDF, the roundisch sidewalls are from 2 layers 4 mm fibreboard, soaked in water and bended/ glued/ nailed over pre curved bottom-top plate. Inside is a brace from side to side, and some dampening sheets on all walls. Will glue some strokes of glass in too. Cabinet has rear-firing bass tube.
Veneering i did in a other way as i did usual, not with tixotrope glue(lot of solvents, i get a sore throat of it) but i did this with the "Klang & Ton" way: woodglue on both sides, let dry 20 minutes, then iron it on, in whool preset of iron. Veneer is paper-backed cherry.
Stand mounts i am thinking of allready.
Daisy Bell
Old 22nd June 2006, 10:05 PM   #10
rho is offline rho  Belgium
Ik ben het helemaal niet eens met je onderschrift.
Anyway....
Nice speakers. Beautiful finish. I'm working with paper back cherry too. Is that just clear lacker or did you finish them with something else? It looks great.
"Suppressed Mids" and tweeter / woofer phase? samtny Multi-Way 28 26th February 2008 09:41 PM
Helper tweeter lens via ~Karlson idea "THE KUP" freddi Full Range 0 25th November 2006 07:54 PM
6.5" silver flute with 1 1/8" dayton silk dome tweeter jadenlinkletter Multi-Way 10 28th February 2006 08:20 AM
suspending a small tweeter in front of woofer for "coaxial" effect? bikehorn Multi-Way 3 2nd January 2006 03:04 PM
Page generated in 0.11095 seconds (77.20% PHP - 22.80% MySQL) with 11 queries
