#31 | |
It's not a spray-can. I'll have to look up the exact type and brand. |
#32 |
Finished the stands, simple made from MDF and PVC rain drainage tube. They will be filled with dry sand. In back tube is a small pipe to put speaker wiring through.
http://img529.imageshack.us/img529/4...tstand2ux8.jpg
Daisy Bell |
#33 |
Daisy Bell |
#34 |
Anyone know how well this would work with the ApexJr ribbon tweeter? If I'm not mistaken, this would lower the efficiency, but eliminate the "beaming" commonly found with ribbons. Seeing as how they're very efficient and cheap, this might work pretty well.
I'm tempted to try making some of these - I, however, would use lost-wax casting instead. Much easier to make multiples. |
#35 |
Nice this cheap ribbon Spasticteapot! Its a pitty i don't live in the us, otherwise would try some.
This ribbon is constructed circular, so horizontal placed and a dispersion cone above it should give same results as with a dome i assume. For the price i would simply give it a try. For a new main speaker i am thinking of a BG Neo 3 and with a cone on the back, working as dipole. Working with 2 long cone excusion paper woofers in d'Appolito in an ML TQWT, don't know the make, but from Canada. Series filtered. As we say in Holland: All this keeps you from the street!
Daisy Bell |
#36 |
Here is the canadian speaker ment.
http://www.creativesound.ca/details.php?model=WR125S Small, so good midrange, and special voice coil construction for larger cone excursion.
Daisy Bell |
#37 | |
I was about to trade for a pair of those myself. I need new bookshelf speakers. |
#38 |
Hi Spasticteapot
This speaker has relative high Qts of 0.61, so a small bookshelf speaker is not very suitable to build with this unit. A small cabinet (+/- 7 litre) is possible though with a coupling cap of specific capacity before unit More ideal a bigger cabinet and Transmission line (lower f -3dB) I just read an article about this unit in Hobby Hifi, a german magazine.
Daisy Bell |
#39 |
Daisy Bell |
#40 |
A perfect tweeter for this task is the new Dayton ND20FA-6
http://www.partsexpress.com/pe/showd...number=275-030 I had to lathe the tweeter i used (Monacor car audio tweeters) For the Dayton it is not neccesary anymore. (But Dayton's dome is slightly recessed in a small horn compared to my used tweeters)
Daisy Bell |
| "Suppressed Mids" and tweeter / woofer phase? | samtny | Multi-Way | 28 | 26th February 2008 08:41 PM |
| Helper tweeter lens via ~Karlson idea "THE KUP" | freddi | Full Range | 0 | 25th November 2006 06:54 PM |
| 6.5" silver flute with 1 1/8" dayton silk dome tweeter | jadenlinkletter | Multi-Way | 10 | 28th February 2006 07:20 AM |
| suspending a small tweeter in front of woofer for "coaxial" effect? | bikehorn | Multi-Way | 3 | 2nd January 2006 02:04 PM |
| Page generated in 0.10950 seconds (77.74% PHP - 22.26% MySQL) with 11 queries |
