Old 20th June 2006, 05:55 PM   #1
fnord is offline fnord  United States
Default Help me out please...
I don't know anything about loudspeakers and I'm doing a science fair project on how to make them louder. I know that a 3 dB increase is twice as much power, but how can you increase the dB? How do you increase watts? Does magnetism have anything to do with it?
Old 20th June 2006, 05:58 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi fnord,
If you increase the magnetic field, you will also alter many parameters of a speaker. This may or may not be what you want (increasing the electrical damping).
What you can do is keep the voice coil cool. That can buy you a couple dB at high levels easily.
I'm sure some other members will chime in with some better ideas.
-Chris
Old 20th June 2006, 06:04 PM   #3
ajazz is offline ajazz  India
Just add a Horn in front
Old 20th June 2006, 06:08 PM   #4
tade is offline tade  United States
Send a message via AIM to tade
or in back
Old 20th June 2006, 06:44 PM   #5
Either way !
If in front keep the rear enclosed with a infinite baffle or a tuned port and if in rear follow the jensen example.
Old 20th June 2006, 06:59 PM   #6
Send a message via MSN to xstephanx
add a larger baffle? this could give you more DBs where the original baffle step would roll off!
hornloading si a good one
reflex laoding can give you some free dee bees at lower frequencies. so that would also include PRs.
CREEEAAAAAMMMMM CHEEEEEESSSSSSEEEEEEE!!!!!
EEEEESSSSEEEEEEHC MMMMMAAAAAEEEERRCCC!!!!
Old 20th June 2006, 07:23 PM   #7
vinylkid58's Avatar
Hi fnord,
Go to the local library, or better yet, your local University library and read up on loudspeaker theory and gather as much info as you can on how they work.
Jeff
Old 21st June 2006, 03:33 AM   #8
Default stick a Karlson slotted tube in front of them...
http://home.planet.nl/~ulfman/
Old 21st June 2006, 05:28 AM   #9
roger_lew's Avatar
fnord,
How old are you so we can get a sense of your background knowledge, and the background knowledge of your audience?
Also what is your budget?
Speakers are basically electric motors that produce sound waves. When they use more power they sound louder because they are moving more air.
A decibel (db) is actually not a measure of loudness. Loudness is a perceptual measure, where decibels are a physical measure of sound pressure (SPL) or volume. How loud humans perceive sound is measured in phons. The reason loudness is measured separately from volume is because human hearing can only hear a limited range of frequencies (20 to 20,000 Hz), and humans do not hear all frequencies of equal volume as equally loud. If you play a sound that starts at 10 Hz (extremely low)and sweeps through the entire range of human hearing you will perceive the sound as gradually getting louder and then gradually getting quieter because of our perception of sound.
Have you seen the rodent detectors that work with high pitched sound waves? They emit sound that is beyond the range of human hearing to annoy the pests. It doesn't bother us humans because it is beyond our range of hearing.
I think ajazz's idea is a good idea for a science fair. Putting a horn on a speaker is sort of like cupping your hands around your month when you yell. You could have some sort of detachable horn that you could remove and replace quickly while the speaker is playing to show people that it actually does make the speaker sound louder! From my experience people like things they can observe themselves.
Hope that helps,
Roger
Old 22nd June 2006, 05:08 PM   #10
I'm 14 and I don't really have a budget because the program I'm in is supposed to supply us with materials, but we have to write to different companies to ask them to donate materials for our cause.
My partner and I are probably going to do Ajazz's idea, but we don't really know what we're going to need exactly. If someone could list the supplies that we'll need and type of speaker or whatever I would appreciate it. Thanks
Page generated in 0.10128 seconds (77.65% PHP - 22.35% MySQL) with 9 queries
