Zaph has another driver grouping up! - Page 3 - diyAudio
Old 24th June 2006, 02:28 AM   #21
ScottG is offline ScottG  United States
Originally posted by Mogar
And the import taxes for this kind of stuff is about 90% over the price of the driver + shipping.
Factory made loudspeakers they not only go out of their original country for less than a store price, also they get less taxes when they arrive here. So, in practice, we pay more to make a diy speaker (comparing with a factory made loudspeaker).
Uhhhgg..
(..and here I thought the UK had it bad.)
That's down-right abusive! Its bad enough the shipping costs are what they are.
As to John's involvement with subjective comments on driver:
I could be wrong, but I'm pretty sure he try's to obstain from this because it is so *subjective*, and because some others seem to take offense where their own views are not "confirmed".
perspective is everything
Old 24th June 2006, 02:09 PM   #22
Default "Bravox" ?
Maybe, but since we don't have a single store that sells good quality drivers (not even on-line), we have to buy from sources like madisound. And the import taxes for this kind of stuff is about 90% over the price of the driver + shipping.
Is there not the "Bravox" drivers' manufacturer in your Country ?
This Company makes drivers of various grades of quality for various manufacturers of loudspeakers in other countries .
I would have thought some of the Electronics parts stores would sell some of the Bravox drivers , as local price would be cheaper than import of even Asian made drivers , and drivers' Specifications would be readily available from the designers at the factory , but as you say not , then I suppose not ...
B&W 601 is OK , but B&W 602 is significantly better for not much extra money -{hear those before you decide} , and better can be made for that money if one knows how .
Alan
Old 24th June 2006, 02:25 PM   #23
Default Re: Re: Zaph has another driver grouping up!
Originally posted by Zaph
Hi guys, thanks for the comments. I just added the Tangband 3" Bamboo cone to that grouping. It's also not a bad performer.
Elsewhere, some other drivers have been added, see my recent blog post.
John
Hi John ,
you beaut. ! , that Scan 18W8531G you have added seems to be the 18W/8531G00 I was interested in , and posted queries about .
I see on your plots that it has a smoother midrange response than I had begun to fear , and a much better CSD than I thought , and good distortion results , thus I suppose the "sliced cone" technology works .
The surprise is comparing it to the two 15W sliced cone models you tested , where the un-coated cone version has the mid peak and associated resonance on the CSD , and the coated cone version has the peak and resonances much reduced - as I would expect , but the 18W/8531G00 is apparently an un-coated cone ! , ? , or , is the 18W you were sent a coated cone ?
I hope it was Tympany who sent to you , and hopefully gave you a pair , so you can make a nice pair of loudspeakers with a pair of those new Scan-Speak tweeters you also have ... Well , its a hope !
Alan
Old 24th June 2006, 06:07 PM   #24
Mogar is offline Mogar  Brazil
[B&W 601 is OK , but B&W 602 is significantly better for not much extra money -{hear those before you decide} , and better can be made for that money if one knows how .
Some say that the bass on the 602 is better, but the midrange from 601 is better. Between bass and midrange, I would stick with a better midrange.
I've heard not too far ago an DIY bookshelf loudspeaker based on Vifa premium line drivers (one 6" driver and a tweeter). Although the bass was surprisingly deep, the midrange performance was below what I would like to hear.
Don't know if those drivers need baffle step compensation. Don't know why, but B&W drivers work very well without baffle step compensation.
Old 25th June 2006, 04:29 PM   #25
Khron is offline Khron  Finland
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
Mr Krutke
I was somewhat surprised not to find the Seas L15RLY/P among the 5.5" drivers you tested (even though you've used them in a pair of bookshelves i'll be "cloning" and mutating soon). I would've been curious as to it's (comparative) performances.
Any chance the L15's gonna be added soon?
Old 27th June 2006, 03:54 PM   #26
Default Monacor SPH-165KEP
Well , if you prefer the midrange after hearing both B&W models with your favorite music , then you will know the one to buy .
Both those B&W models are now in series 3 form , that is they have both been developed and revised , thus their cross-overs will have been fine-tuned to get the best possible audio response for when listening on the recommended Vertical Axis , thus their phase response on that axis may now be good enough for satisfactory listening without need for baffle step compensation . Try listening on the woofer axis also , as that part compensates for the arrival times difference , or even a little further vertically off the tweeter axis to hear if the midrange information sounds more integrated - that is - if more true to life . You will only miss a little of the highest treble frequencies when listening off the tweeter axis vertically , and as B&W tweeters are often a bit bright in the 600 series , this may also be a more realistic sound balance off vertical axis .
For DIY , as you seem to like the B&W 6 1/2" bass-mid driver , look at www.monacor.com , and Search in that site for 165KEP .
When you get to the page , click on the picture of the 165KEP driver and the Specifications will be displayed . No it is not a B&W driver , but it looks good to try for DIY , and can be bought Mail-Order .
Alan
Old 27th June 2006, 09:53 PM   #27
MarkR is offline MarkR  United States
These tests are supported by the community. I don't actually buy drivers myself, loaners are sent in by others. Well, I do buy some, but I certainly don't buy all of them. My own resources only go so far.
Zaph,
I just recently got a pair of Ascendant Audio 6.5 poly midranges. I was planning on putting them in my gf's car but due to my father having a stroke the day after I ordered them I wont be getting to the project anytime soon. I would gladly send them to you to test if you are interested. I am in N. Illinois and my father lives in/near Appleton WI. Just email me if you are interested.
-Mark
Old 29th June 2006, 03:54 PM   #28
Default Re;- baffle step compensation .
I have now realized that Mogar may have been refering to the type of baffle step compensation which is designed to compensate for the change in forward radiation from the bass/mid driver in regard to wavelength and baffle dimensions .
In my post above I was writing about time delay - the arrival time difference between cone and dome drivers both mounted on the same plane of baffle . Why that entered my mind is because his mention of B&W reminded me of the original B&W stepped baffle loudspeakers , designed to time align the drivers , and as B&W still do to some degree in some {only} of their current 700 and 800 series model loudspeakers , and as do a few other manufacturers .
I hear the time arrival effects more-so than the baffle dimension radiation effects in loudspeakers I build and modify .
Alan
Old 29th June 2006, 07:43 PM   #29
I realize that there are a lot of good driveres out there and one can't possibly test them all but I never see any Peerless drivers in Zaph's test groups. I would really be interested in seeing some reviews on the Exclusive line.
G.
If you take something apart and put it back together again enough times, eventually you will have two of them.
Old 29th June 2006, 08:26 PM   #30
ShinOBIWAN's Avatar
G.
You spoke too soon
http://www.zaphaudio.com/blog.html
The more you know who you are and what you want, the less things will ever be the same.
Anyone check out the new ZAPH driver at Madisound? madisonears Multi-Way 6 13th August 2009 05:20 AM
Simulating Zaph's L18/TBFCG design using his separate driver measurements Jay_WJ Multi-Way 0 20th April 2007 10:00 PM
zaph's Hi-Vi B3S single driver modded? Scott_fx Full Range 6 10th February 2007 02:21 AM
My Zaph Hi-Vi B3S Single Driver System Project zei Multi-Way 12 16th April 2006 09:04 AM
The Filter design for Zaph,s Hi-Vi B3S single driver system zei Multi-Way 5 25th October 2005 08:00 PM
Copyright 1999-2017 diyAudio
