Old 19th June 2006, 07:30 AM   #1
Default micro drivers?
I just finished building my first subwoofer. I live in apartment, so my friends had a great time joking at my expense: "The problem speaker building as a hobby is, the better you are at it, the more your neighbors hate you."
Still, my new subwoofers sounds great and although I keep tweaking it, I am quite happy with it.
first sub -- cheap style
But all the joking got me thinking, and I decided to build something tiny and portable and for my next project.
I want o use the kind of mini drivers that are used in portable iPod docking stations like this:
http://www.alteclansing.com/product_...asp?pID=IMPLUS
Does anyone know where to buy these 1" full-range mini drivers. Or perhaps they are headphone drivers? I can't seem to be able to Google anything, and Madisound told me they don't sell any.
Thanks a bunch.
Old 19th June 2006, 11:51 AM   #2
well madisound didn't exactly told you the truth then
http://www.madisound.com/cgi-bin/ind....21334&pid=101
http://www.madisound.com/cgi-bin/ind...=6410104.24961
at partsexpress :
http://www.partsexpress.com/pe/pshow...=297-411&DID=7
Old 19th June 2006, 12:37 PM   #3
Timn8ter's Avatar
Keep in mind that to get those little drivers to produce any kind of bass the sensitivity suffers. IOW, you could use a SI T-amp but only if you're right next to the speakers.
Not a criticism, just a reality check.
I got my hands on a pair of OEM mini-drivers and they're pretty impressive (with 80db sensitivity). I think we'll see more coming.
Old 7th July 2006, 04:56 AM   #4
Here is the result so far:
http://www.flickr.com/photos/gmarceau/179378919/
Easier speakers ever. 1" driver, 1" Iron pipe and a drop of super glue. I also had to stuff them with a little bit of coton. The Loudspeaker Design Cookbook has a chapter on transmission line that discusses how to get this right.
Naturally, they don't get much bass. Nevertheless, I am quite pleased to get some nice imaging out of 20$ worth of driver (2x6$) and material (2x4$).
I'll try do build a small sub for them next.
cheers
Old 7th July 2006, 03:01 PM   #5
Send a message via MSN to xstephanx
smallest baffle EVER....i dare you to bsc them, hello 50db sensitivity! you coudl even LT them, with a little work you could have the LEAST sensitive speakers on DIYaudio...
...this is why im in summerschool.
CREEEAAAAAMMMMM CHEEEEEESSSSSSEEEEEEE!!!!!
EEEEESSSSEEEEEEHC MMMMMAAAAAEEEERRCCC!!!!
Old 7th July 2006, 03:29 PM   #6
Those drivers look like this one:
http://www.aurasound.com/pdf/NSW1-205-8A.pdf
Am I right ?
Charles
Old 7th July 2006, 05:53 PM   #7
No, not the Aurel. They are the HiVi B1S that Nemophyle suggested.
xstephanx: these are transmission lines, not baffles. they are pleasantly loud for their small size.
Micro MR-711, My first DD Turntable bulgin Analogue Source 0 31st May 2009 03:14 PM
Micro Jacks and Micro Pins for board-board connection jazzist Parts 1 12th May 2008 03:02 PM
micro-amp SE with 2,5k OPT+ boergars Tubes / Valves 3 11th July 2007 02:58 AM
usb-programmable micro? nuppe Parts 7 6th January 2005 04:32 PM
Micro DQ-5 TT anyone? Lorne Analogue Source 0 22nd November 2004 03:36 PM
Page generated in 0.09900 seconds (76.22% PHP - 23.78% MySQL) with 10 queries
