Old 18th June 2006, 11:01 AM   #1
Default WM-61A + LSPLab, why so bad? Heelp!
Hello
I have this gear
Panasonic WM-61A mike
Behringer Mic 100 Mike preamplifier.
LoudspeakerLab 3.1
Soundcard: Soundblaster Auidigy 2ZS
I am supplying WM-61 as they wrote in LSPLab help section, with ektra resistors attached and with 9V dc.
When i try to measure different (bought) loudspeakers, the frequence responce is falling above 2Khz and ends with -15dB at 20Khz!!
Can anybody help me with a little setup guide or good advice for using WM-61A with loudspeakerLab?
And why does the Creatives "mixer" turn off Line input every time you press play in LspLab??
Kim
Old 18th June 2006, 03:46 PM   #2
You might want to consider using a mic preamp like the one by Eric Wallin. I have built this uint and it works very nicely with LspLab. Also have you selected your mixer under the settings tab in LspLab?
G.
If you take something apart and put it back together again enough times, eventually you will have two of them.
Old 18th June 2006, 04:38 PM   #3
I suppose you are using pink noise as a test signal
Either use a loopback cable from output directly to input to correct for this or switch to white noise.
Cheers!
Old 18th June 2006, 05:42 PM   #4
Hey
Thanks both.
Yes i am using white noise 20-20Khz
Have you calibrated your microphones and how?
Any other thing to remember to set in lspLab?
Kim
Old 18th June 2006, 07:42 PM   #5
So by using white noise rather than pink i guess you now get flat frequency response?
I haven't calibrated my microphone. I use a behringer ECM8000 and I am quite pleased with the results. A few weeks ago i gave the panasonic capsules a go too and they seem very good as well.
As for LSPlab i'd suggest using more pre avarages and the dual channel FFT is a very useful feature to compensate for soundcard frequency response.
Anyway give us some more information. What is your measurement setup?
Old 19th June 2006, 05:03 AM   #6
Hello
I have have only tried white noise until now.
Maybe your right if I try to start with a loop cable and see if something is wrong, I mean if the sound or something else is destroying the frequency liniarity!
May I can try to calibarte the mike by using a loop cable first instaed off a real calibrated mike if you can follow me?
What do you mean by the measurement setup?
What settings I use in my program?
Kim
Old 28th July 2006, 09:31 PM   #7
Hello ALL
I can see now that I was so confused last time!!
The reason why I got so bad measurement responce, were because I have marked Dual FTT and not used a split cable back to soundcard, and thereby it compared the measured signal with "nothing"!!
Have until widere turned Dual Channel Ftt off and I can measure up to 18Khz! (Tweeter is Scanspeak 9700 goes straigt to 30Khz)
Using the window " ½ EXT. Cosine Bell"
Have also found out how to prevent muting Line input when pushing "play" in LSPlab, ( Measurement settings-> Advanced)
Another measured same tweeter in same loudspeaker box up to 30Khz same soundcard too, but used a ECM8000 instead.
Can ECM8000 mike measure higher than WM-61A?
What settings in the program should I look after?
What measurement "window" are you guys using?
Thanks for all!
Kim
LspLAB 3.01 - impedance? Audist Multi-Way 4 1st March 2008 02:43 AM
measurement on LspLAB Audist Multi-Way 7 31st March 2007 08:40 PM
HEELP RCA cables makes my amplifier hum!! kimschips Solid State 9 8th October 2005 09:13 AM
LSPLAB 2.20 - measurement box v3 lmic Multi-Way 0 18th February 2004 05:18 PM
Page generated in 0.10679 seconds (79.24% PHP - 20.76% MySQL) with 10 queries
