Old 14th June 2006, 07:28 AM   #1
Default help speakers wrong ohm rating
Hi All
I have a set of wharfdale speakers that say 8 ohm on the name plate. When I use a fluke meter they read 6 ohms and 5.8 ohms.
Can someone tell me what to look for that could cause this.
KD
Old 14th June 2006, 07:41 AM   #2
It is normal for an 8ohm driver to measure 6R for DC resisitance.
/sreten.
Old 14th June 2006, 07:59 AM   #3
Jennice is offline Jennice  Denmark
Tradeups,
A little more explanation. There are more details to this subject, but the simple (not complete) explanation is:
Your speaker drivers have a magnetic coil inside them. This coil generates part of the magnetism which moves the membrane.
These coils are inductors, which gives them an "inductance", which is a sort of resistance that increases with frequency. Ignoring the influences from the driver mechanics (which influence the measured inductance), your measured resistance Z would be like Z = R_fluke + R_inductance, where R_inductance is K*frequency
(K would consist of a number of factors, but ignore them for now).
When you measure with the fluke meter, you measure at DC, or frequency=0.
When playing music, frequency is higher than 0.
Therefore, your amplifier sees a higher resistance than what you measure with your fluke meter.
Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
Way of testing a speakers power rating? Gorbee Multi-Way 4 25th August 2006 11:41 PM
RMS Rating of Speakers xitronics Multi-Way 10 26th August 2005 07:36 AM
Transformer VA Rating vs. Current Rating JhonDoe Chip Amps 45 5th June 2004 01:11 AM
What's wrong with using extension cords for my outdoor speakers wires? Cal Weldon Multi-Way 15 23rd January 2004 12:47 AM
Page generated in 0.07388 seconds (67.48% PHP - 32.52% MySQL) with 10 queries
