Weird 2 way Crossover
Old 12th June 2006, 07:44 PM   #1
]|[ GorE is offline ]|[ GorE  United Arab Emirates
Question Weird 2 way Crossover
My Panasonic bookshelves ( with a 5 inch aramide glass fibre cone and a 25mm Semi-dome tweeter) are stated to crossover at 4.5 Khz according to the HTIB manual.
And the only components on the crossover pcb are :
2 caps : 2.2 uf and 4.7 uF metallized polyester 75V
One air core inductor. (forgot the value)
What sorta crossover is this ?? I am asking because i want to upgrade it.
I hope that this thread will get atleast one reply.
Old 12th June 2006, 08:23 PM   #2
RDV is offline RDV  United States
It's like my Sanyos, it's probably got a 1st order(just a cap) for the tweeter, and 2nd order(cap & inductor) for the woofer.
RDV
Old 12th June 2006, 08:25 PM   #3
The inductor is probably a .56mh if the woofer is 8 ohms.
RDV
Old 12th June 2006, 08:28 PM   #4
Any chance of upgrading it or changing it for the better ??
Old 12th June 2006, 08:33 PM   #5
I'm trying to do the same thing and what they're telling me is that without measuring equipment I'm just shooting in the dark so to speak.
Do they sound bad as is?
RDV
Old 12th June 2006, 08:49 PM   #6
pwillard is offline pwillard  United States
Quality in an Air Core inductor is harder to achieve than say... upgrading a cap.
It's not like it has a voltage rating. It's not a radio frequency coil, so that doesn't come into play. With Air Core, there is no permeability of the ferrite or other core material to take into account.
If it were me... I'd upgrade the caps and leave the coil alone.
pw
Old 12th June 2006, 09:00 PM   #7
They have oodles of detail.No problem with the bass or midrange.
Its got a shiny treble.Getting rid of it by setting treble to -1 in the tone controls.
Old 12th June 2006, 09:07 PM   #8
They probably neglected to pad the tweeter in any way. If you added padding resistors you'd have to change the crossover values then because the impedance would change. It sounds like it would be more trouble than it would be worth IMO.
RDV
Old 12th June 2006, 10:01 PM   #9
What do you mean by change of impedance. Isnt that what the R1,R2 of L-padding are supposed to do ?
Old 12th June 2006, 10:13 PM   #10
When impedance changes, so does the crossover point.
RDV
Weird 2 way CrossoverHide this!Advertise here!
weird old amp:need help bullpeters Tubes / Valves 1 6th May 2009 08:20 AM
combining different speaker wires (weird external crossover problem) Ang Everything Else 2 19th January 2007 09:55 PM
Here is a weird one mashaffer Solid State 2 26th March 2006 01:23 AM
weird karma Everything Else 1 26th May 2004 04:10 AM
weird karma Everything Else 8 6th May 2003 11:42 AM
