Old 11th June 2006, 07:32 PM   #1
Default Port vs. PR - midrange quality
I'm working on the design for a 2-way using the Eighteensound 12ND710 and BMS 4552ND on XT1086 horn/waveguide.
The woofer has a very low Q and the only way to get useful low end is by using porting or PR.
At first I assumed a PR would be less problematic than a port as far as midrange coloration, since the latter gives a direct path for sound to escape from the cabinet.
Upon further thought, the PR is not opaque acoustically and has a much larger area. Fb will be about 55 Hz, so the PR will have a regular cone.
Given how much sound passes through a solid wall, I imagine a cone lets a lot through.
Does anyone know of any studies where a port or PR was mikede for the midrange freq?
The only data I've seen was in LDC, where Dickason covered only blips in FR due to "mutual coupling", whatever that means.
Noah
Old 12th June 2006, 10:21 AM   #2
Stereophile have loads of graphs of port output.
/sreten.
Old 12th June 2006, 04:27 PM   #3
Good point!
I looked here
http://stereophile.com/floorloudspea...ef/index3.html
and see that after a few hundred Hz the port is 25 dB down, and that they commented on the colorless midrange.
I'll keep the ports as far from the woofer as possible, and create a labyrinth of 1.5" foam that should absorb the midrange but be transparent to bass.
Noah
Slot port vs circular port equivalence Brisso57 Multi-Way 12 21st February 2009 02:38 PM
High Quality 100 uF midrange cap. Curmudgeon Parts 9 31st July 2007 05:52 AM
Single Port Vent Better than Dual Port? Daveis Multi-Way 18 15th July 2007 05:12 AM
Port Midrange Leakage jimangie1973 Multi-Way 26 24th January 2007 09:37 PM
To port or not to port? Newbie with newly built mains starquake Multi-Way 1 18th December 2004 12:51 PM
Page generated in 0.08613 seconds (74.07% PHP - 25.93% MySQL) with 10 queries
