Thor/Viva/XO question
Old 29th November 2002, 03:41 PM   #1
w.gruenewald is offline w.gruenewald
Default Thor/Viva/XO question
I've completed the Thor cabinets as per plans provided by Seas. However, I plan on using the following drivers: VifaXT25TG30-04 tweeter, and PL18WO-09-08 mid/woofers (2), due to cost. I've offset the tweeter,so as to "mirror image" this design. I am in need of a cross-over design for this project, as well as opinions from those who have build this design, and from those who have experience with these drivers. Anything is appreciated.
Old 30th November 2002, 03:03 PM   #2
FrankDIY is offline FrankDIY  Canada
FrankDIY's Avatar
Well, you have to start from scratch. There a lot of steps to design a good crossover. In short, you have to measure the drivers impedence with a software, determine a good impedance compensation network and remeasure the system. With the new impedence curve, you can determine the impedence at the crossover point and then design the crossover from this number. You will probably need an L-Pad for the tweeter and maybe a notch filter if your crossover point is too low. Nobody can pretend design a crossover for you without having the real number for your drivers.
search on google and here for crossover design and you will find usefull reading.
Good luck!
Imagination is more important than knowledge. knowledge is limited, imagination encircles the world. Albert Einstein
FrankDIY's Audio Corner
Old 14th December 2002, 02:07 PM   #3
bacworth is offline bacworth
Send a message via MSN to bacworth
I don't know if I would be using those speakers in those cabinets, I thought they were designed for the Excel range. Anyways, I have used the Vifa driver you talking about, don't know exactly the specs on those seas drivers but i would cross them @ 3000hz - 4000hz 18db. It is a tought call without the specs as Francois suggests.
Brent
Old 14th December 2002, 02:52 PM   #4
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
I am not so sure that those driver will work very well in that enclosure. The excel/millennium seas drivers were crossover at 2.5khz. The article on the design is at:
http://brian.prohosting.com/nancy/thor.pdf
The driver parameters are different, so I don't think that the cabinet would be optimal. I would save your money and buy the excel drivers. I love the sound of the Thor TL speakers.
Here are pictures of mine:
http://brian.darg.net/thor
Brian
Old 14th December 2002, 03:00 PM   #5
BrianGT's Avatar
Here are the specs from the respective websites:
Brian
Old 14th December 2002, 03:06 PM   #6
BrianGT's Avatar
tweeters:
Brian
Old 14th December 2002, 07:40 PM   #7
jgwinner is offline jgwinner  United States
I agree with everyone. I haven't heard my Thor's yet (still working on the cabinet) but I agree, I think with a different driver you'll have to rethink everything.
The Transmission line length is based on the Fs, and the two drivers have a different Fs.
When I built my sub I finally realized there were 'no magic numbers'. If I made my sealed enclosure a few cubic inches too big or small, it only moved the sound toward or away more Q.
However, with a TLine you are working on a 1/4 wavelength, and that wavelength is different.
Or at least, I think. I think you should sit down with some modeling spreadsheets (i.e. Martin's mathcad models) and fiddle with it.
A cheaper TL like Thor is a very worthwhile project, however, I think it's an excellent idea.
Also, Martin and Dave weren't convinced that the Thors were an optimal design, so there is some additional work on the design that could be done anyway. I'm 1/2 way thorugh this, but I quit armchair quarter backing and just BUILT the things as is to get something going SO it wouldn't hurt if there was more work done on the basic Thor design.
== John ==
Thor/Viva/XO questionHide this!Advertise here!
Tubes for Viva Solista 845 SET amp angeloitacare Tubes / Valves 9 19th September 2008 03:22 PM
L-Pad question... Thor crossovers mathman Multi-Way 5 14th November 2006 09:39 PM
Ariel Vs. THOR? top5 Multi-Way 8 1st December 2004 10:53 PM
New Thor TL's greenie512 Multi-Way 5 6th November 2004 09:18 PM
Thor-TL kit Vuamp2 Multi-Way 0 16th April 2003 12:02 AM
