building an A/B speaker switch - would appreciate input
Old 9th June 2006, 02:09 PM   #1
JMB is offline JMB  United States
Default building an A/B speaker switch - would appreciate input
I am designing and planning to build an A/B speaker selection switch box. I want to put volume controls on each speaker selector so I can compare pairs of speakers at equal volumes. Can I just use an adjustable L-pad or does it require a volume control like the wall mount type units? I assume that things like a volume control (Radio Shack 271-1732 for example) are line level and not speaker level controls.
Any guidance would be appreciated.
Also, if anyone has done something like this, I would love your input, feedback, and even examples of what you have done.
Thanks,
Jay
Old 9th June 2006, 02:40 PM   #2
R.I.P.
you cannot use L-pads to equalise volumes as they seriously
compromise the source impedance seen by the speaker and
generally will the turn the bass end into mush.
The simplest / cheapest way of switching is a dual gang lightswitch
in a box, the negative is common and the switches select the speaker.
/sreten.
Old 9th June 2006, 05:56 PM   #3
Any idea how the wall unit volume controls such as Partsexpress 300-546 or 300-548 are put together? They are speaker level volume controls?
Thanks,
and thanks for the input thus far,
Jay
Old 12th June 2006, 10:53 AM   #4
R.I.P.
a proper volume control would need tapped transformers which the Dayton parts appear to have :
Bass power handling will not be good though, accurate a/b comparisons will not be possible.
/sreten.
Old 12th June 2006, 11:13 AM   #5
rpapps is offline rpapps  Antarctica
"The simplest / cheapest way of switching is a dual gang lightswitch
in a box, the negative is common and the switches select the speaker." /Qoute
Since amplifier is not specified, have to consider it might be bridge configuration so double pole switching is recommended.
Switchable volume controls at amp input would be simplest way to match levels.
Cheers
Rob
Old 12th June 2006, 05:35 PM   #6
R.I.P.
Originally posted by rpapps
in a box, the negative is common and the switches select the speaker." /Quote
Rob
The dual gang lightswitch will work perfectly well with a bridged amplifier.
In the above case negative is not also earth, but its still negative.
/sreten.
Old 16th June 2006, 12:26 PM   #7
bluesmoke is offline bluesmoke  Canada
Wow, never would have even thought of the lightswitch idea...
Just built my own A/B switchbox a short while ago. Used a decently affordable DPDT toggle that I was satisfied that it had a solid and very strong 'SNAP' when making contact (mechanically). Used a strong plastic enclosure (good for electrical isolation, if placed on or near your equipment; no chance to short to earth), but will probably rebuild into a nicer enclosure when I have time and can afford it. I cheaped out and didn't invest in gold plated posts at the time... a big (mostly aesthetic) regret that would have been easy to avoid. Still haunts me.
Like everyone is saying, volume pads in the speaker section are not a great idea.
building an A/B speaker switch - would appreciate inputHide this!Advertise here!
Input Switch? markw51 Tubes / Valves 0 23rd December 2006 01:08 PM
Need yea or nea on input switch davidlzimmer Chip Amps 20 10th October 2006 09:55 PM
Building a cut off switch. mpm32 Instruments and Amps 1 17th May 2005 02:16 PM
input switch for BOSOZ Gabrielshorn Pass Labs 1 19th September 2003 06:57 AM
Copyright ©1999-2017 diyAudio
