Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 4th June 2006, 09:00 PM   #1
LowVoltage's Avatar
Default Advice on adding a tweeter to Pioneer B20 8" FR
I've just finished building .67 cu ft. vented (BR) cabs for these drivers. I've let 'em burn in for two weeks now. And I'm generally pleased with the end results. However, "beaming" does seem to be a problem (typical of some full ranger's). I've tried A rear firing piezo, that with L-pad added is still overly bright... to me.
The Pioneer's do have a nice bottom end and good mid range. I would think that I would be able to cross them over a little higher if necessary. I'm looking for a tweeter that has a nice silky, smooth top end and a price in keeping with the $20 or so purchase price of the Pioneers. I've included a link to the speaker spec sheet
http://www.partsexpress.com/pe/showd...number=290-045
A. Recommendation for a tweeter
B. Recommendation for the attendant XO. (I can build what ever I need) and lastly:
I want to include an L-pad on this tweeter as well. Where do I insert that in the XO design....before or after the XO. My current L-Pads are 8 ohms. If I wind up with a tweeter thats rated at 6 ohms, would I be able to use the *ohm pads?
Thanks in advance for any help
Mike
Old 5th June 2006, 09:46 AM   #2
sreten is offline sreten
This ?
http://www.partsexpress.com/pe/showd...number=270-102
or This ?
http://www.partsexpress.com/pe/showd...number=270-049
The L-pad goes between the tweeter and c/o capacitor.
For a simple first order c/o on the tweeter only 1uF = 20KHz, and you
scale from there, e.g. 10KHz = 2uF, 2.7uF = 7.5KHz, and 3.3uF = 6KHz.
I'd say 3.3uF is the lowest frequency you should use.
/sreten.
Old 6th June 2006, 12:19 AM   #3
LowVoltage's Avatar
Thanks sreten:
Instead of a simple 1st. order X/O on the tweeter only, I think I will go with a 2nd order on both, what will now be a woofer, and the tweeter. I can cross them over a little higher. I was thinking 4000 to 5000 Hz. This would retain the character of the Pioneers and give me a little relief in the top end, I was thinking along the lines of a fabric dome tweeter, such as Hi-Vi K1 or the Audax TU025F1.
I know the issue of a 4/6 ohm tweeter could probably addressed with fixed padding resistors on the tweeter, but.......i would still like to be able to control the output level the tweeter. And I don't know how to design an X/O network like that. I guess if I stick to 8 ohm tweets that would eliminate THAT problem.
Mike
Old 6th June 2006, 10:37 AM   #4
By adding a 2 ohm series resistor to a 6 ohm tweeter you can use
the L-pads ideally, though they'd still work quite well with 6ohm.
Going for a proper 2-way you really shouldn't use a twin cone driver.
Also you should read up on baffle step compensation.
Using this you can effectively boost the treble of a twin cone driver.
http://www.quarter-wave.com/General/BSC_Sizing.pdf
http://www.quarter-wave.com/General/BSC_Variable.pdf
For lots of info on tweeters see here :
http://www.zaphaudio.com/tweetermishmash/
/sreten.
Thread Tools
Advice RE: adding more speakers dylanclark112 Multi-Way 1 25th February 2008 07:24 AM
Adding a tweeter to DX3? KMMM Full Range 22 4th November 2007 10:52 AM
Adding Preouts to a Pioneer Receiver LightwaveDude Parts 5 14th July 2007 12:50 AM
Looking for advice on "sweet" tweeter? Leonidas Multi-Way 7 20th February 2006 09:25 AM
Advice on matching a HE 12" mid and tweeter paulspencer Multi-Way 17 22nd July 2005 11:54 PM
Page generated in 0.15709996 seconds (82.41% PHP - 17.59% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
