Old 2nd June 2006, 07:51 PM   #1
turk99 is offline turk99  United States
Default Speaker switches
My Stereo has A B A+B capabilities, so I have two rooms I control for my music. The rooms are in opposites ends of the house, so the speaker wire goes through the basement.
I have a workroom in the basement, and would like to occassionally listen to music down there. Is it possible to get a switch of some kind, so I can intercept the feed from one of the rooms?
Old 2nd June 2006, 07:55 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Sure, just make sure the switch disconnects the speakers upstairs if you listen in the basement. If you don't you most likely will halve the impedance and your amp won't like that.
/Hugo
FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers chris-man Swap Meet 1 28th May 2009 11:47 AM
Switches chipco3434 Parts 1 16th November 2005 06:56 PM
Switches LizardDefence Everything Else 5 1st June 2005 08:52 PM
A simple way to create dual(or more!) rotary switches out of single rotary switches stappvargen Pass Labs 14 16th April 2004 11:33 PM
Using mosfets as switches nobody special Everything Else 8 3rd December 2002 12:35 PM
Page generated in 0.06912 seconds (66.53% PHP - 33.47% MySQL) with 10 queries
