10 Inch Sub
I was asked to find the Thielle Small parameters and properties of a subwoofer for a friend of mine. All I need is the frequency response. The parameters I have found so far are listed below. I can set up and do a near field frequency response measurement but if I could just calc it somehow it would make my life easier.
Fs(Hz) = 33.79
Qms = 5.2537
Qes=.4616
Qts=.4883
Vas(ft^3)=.83
Bl(N/A)=7.82
Efficiency(%)=.09
Rvc(Ohms)=1.79
Le(uH)=652.19
Xmax(In) Peak to Peak = 1.17
Sensitivity 85 db@1w/1m
SdIn^2) = 51.84
Vd(ft^3) = .035
Inverted Cone Volume(ft^3) = .047
Magnet and Cone Volume(ft^3) = .092
Mounting hole ID 9-1/4(In)
Mounting depth 8 inches (In)
Continuous power 500 watts RMS
80 oz double stacked magnets
Fs(Hz) = 33.79
Qms = 5.2537
Qes=.4616
Qts=.4883
Vas(ft^3)=.83
Bl(N/A)=7.82
Efficiency(%)=.09
Rvc(Ohms)=1.79
Le(uH)=652.19
SdIn^2) = 51.84
Vd(ft^3) = .035
The Sub
The manufacture actually handed these to me and said tell what they can do. Can you find the parameters? Should we put them in production and so I am playing with them. It is a car sub. That massive Xmax is killing my port lengths. The minimum port diameter is calculated at 7.2 inches and is super long in a SBB4 or QB3. The Vb is .7 ft^3 in a SBB4 but The vents are super long. I am trying to talk the manufacture into making me some passive radiators for them. You could build a good sub in a small package with a PR instead of a port. I have looked at other manufactures making similar subs but the boxes are over twice the volume I would use and the ports are not quite as large in diameter as what I calc but I suspect the large volume and shorter diameter ports are just to keep box size down. It appears to be the trend these days. I am actually writing the owners manual for them and I am done except the frequency response.
- Impedance Question
