i am going to pull out the focal speakers in my car. plan to sell my car
can anyone recommend a cabinet type and dimensions to house this speakers? it will be powered by a charlize t-amp. woofer specs tweeter specs thanks
noob on the block |
#2 |
Since the QTS is so high I would recomend a sealed enclosure. I'd suggest some 28 litre sealed enclosures. You won't have much bass, but I think that would be best.
Josh |
#3 |
thanks ed.
anymore suggestions
noob on the block |
#4 |
Long time lurker first time poster,
I to are looking at using the same speaker's for my centre channel speaker, in a custome designed box so it's noe so deep like normal centre speakers, Any feedback would be awesome, Cheers Dale H |
#5 |
28L for a sealed box is far too large, driver Vas is 7L so going larger than 10L will be pointless. If you intend to go full range you will be far better off building something that will work well as a hifi speaker and selling the Focals for in car use. http://www.zaphaudio.com/audio-speaker17.html |
#6 |
Thanks for the info sreten,
I've had these speakers for a while, i'm going to make up a box, So you would suggest that a 7L bix would be sufficent? Anymore tips would be awesome? Cheers Dale |
#7 |
TBH the only way they could be sensibly used is set to small via a AV amplifier which would control the bass response. At this point though the crossover will be completely wrong as there is no baffle step compensation or diffraction ripple compensation. Put in boxes as is they will sound nothing like they do in-car. They are engineered to go in car doors and the like, Fs is double, Vas a quarter, Qts double the values you'd expect from a hifi 6.5" unit. |
#8 |
Talking about car speakers, I am just curious, could 8 inch 2-way car speaker be used in OB design as mid-tweeeter combo of course paired with some 12 or 15 inch bass drivers. Actually, I have as surplus a pair of 8 inch Pioneer, E-motion series 2-way (maybe 3-way, I am not tottaly sure) cevlar cone car speakers, but very nice sounding ones and don't know what to do with them. I don't have their T/S specs. best regards, |
#9 |
Basically yes. You should be able to use a 2-way car speaker on a large open baffle. |
#10 |
Hi Sreten
Thank you very much for reply. best regards |
| BIB cabinet for Focal 5A1 | wydrus | Multi-Way | 2 | 8th November 2007 09:10 PM |
| isophon PH2132E - cabinet suggestions? | MichaelPublic | Multi-Way | 0 | 18th December 2006 02:47 AM |
| Cabinet varnish suggestions | lmcmaju | Multi-Way | 3 | 9th September 2004 03:30 AM |
| cabinet suggestions for dual 15" jbl woofers | djquick_silver | Multi-Way | 4 | 24th September 2002 06:56 AM |
| Suggestions on stiffening woofer cabinet? | Keith TDI | Multi-Way | 4 | 17th March 2002 06:33 PM |
| Page generated in 0.12508 seconds (79.96% PHP - 20.04% MySQL) with 10 queries |
