i'd like to build a set of monitors based on a specific box. Either of these two Parts Express options.
302-700 or 302-710 i saw this ZaphAudio Monitor using some Seas drivers and the 302-710. Could this design be modified to use Seas Excel drivers? i was hoping to use the E036 or E006 Tweeter and the E015 or E037 for the Midbass. the speakers will be used in the bedroom but i'd like to get something deeper than 80Hz. i was also considering getting the Rega Brio to power the system. this integrated only has 38 watts per channel. will that be enough to power the above speakers? (assuming moderate listening levels) thanks, kevin |
#2 |
No you cannot change the drivers in the design. The design is far better value that any design using Excel drivers. What makes you think it only goes to 80Hz ? /sreten.
| Anyone built a tube-based (6BE6 or 6HS8) volume control? | GordonW | Tubes / Valves | 8 | 31st May 2008 10:24 AM |
| The A4 monitor, best mini monitor? | KURT | Multi-Way | 5 | 26th April 2005 02:34 PM |
| Has anyone built GC into a speaker to make a self powered monitor? | e.lectronick | Chip Amps | 22 | 1st October 2003 09:25 PM |
| Page generated in 0.07010 seconds (71.99% PHP - 28.01% MySQL) with 10 queries |
