Driver suggestions 150Hz-2KHz Xovers - Page 5 - diyAudio
Old 29th May 2006, 07:28 PM   #41
Tenson is offline Tenson  United Kingdom
It looks shiny and is 4 Ohms nominal too, which is fantastic. The Lab12 was 8 Ohms which was making it quite hard to find an amp to give 500Watts @ 8Ohms.
Great I think I know what I will do then!
Old 29th May 2006, 11:18 PM   #42
ScottG is offline ScottG  United States
Originally posted by Tenson
Scott, what sort of music do you listen to? I can't help but think it must be quite different to me.
I can't find a lot on the Veravox but I'm not really bothered by efficiency as I said before. I will have 500watts RMS for the midrange lol! It just needs to sound good. I know efficiency is important to good sound but it is not the be all and end all.
The linear decay plots donít seem to be available for a lot of drivers.
Again, anybody got experience with the Dayton RSS315HF? How high can it be used?
Almost everything but C&W and RAP (..and sometimes a little from those as well like classic SugarHill or pop'esq or blues'esq C&W.)
Every once in while I just love to "crank-up" some AC/DC LIVE!.. and with a recording like that higher eff. drivers just seem to "come-to-life" more. (..and this goes along with that recent post on hifi drivers vs. pro drivers.)
perspective is everything
Old 31st May 2006, 07:32 AM   #43
yes this dayton driver looks spot on for what you are searching for . It's true that visaton drivers are generally a bit expensive, especiammy if you compare them to the daytons
Just on a side note : Tenson, do you realise what kind of SPL you are gonna obtain with 2 12" high excursion drivers ? More than you can handle, even with the visaton driver, even EQ'ed, except if you listen very far and have a very big room
Old 31st May 2006, 11:03 AM   #44
What?! I canít hear you!!
About 112dB at 20Hz with room gain? Sounds about nice From 40-50Hz a second open baffle 12" will kick in but I will need to limit the closed driver to what the open baffle driver can do so they are playing at equal level. I'll get about 110-115dB in room over the entire audio range. They should be quite compact as well. Anyway it is not about playing super loud it is about not being stressed when playing normal loud.
Old 2nd June 2006, 11:47 PM   #45
Heya lads!
So, is there anywhere I can get the Dayton RSS315HF for a decent price? I am in England, so if I buy them from PartsExpress I pay about the same amount in postage as I did for the woofers!
Old 3rd June 2006, 06:46 PM   #46
i know only ONE other place to buy dayton drivers and it is in germany, not in england
Die boxen baustelle
Old 12th September 2007, 01:57 PM   #47
bubbles is offline bubbles  United States
Default volt bm220.8
the volt bm220.8 is a great match to the raal 140-15
I have used it with great results and its is very robust.
clean fast sound, double spider!
Old 15th September 2007, 10:47 AM   #48
el`Ol is offline el`Ol  Germany
The Beyma Pro6MI would be loud, easy to x-over in the treble, maybe 6dB, not too expensive and has OB-suitable Qts.
http://car.beyma.com/ENGLISH/listapr...?id_familia=13
Somebody here reported good success with the Veravox 7X plus raal in OB, but would be more expensive and I have never seen a power handling value.
150hz crossover oaristys Multi-Way 18 22nd June 2009 01:27 PM
Driver suggestions Marcel_D Multi-Way 3 19th October 2007 09:41 AM
Any problem crossing stereo 12" subs at 150Hz? Dumbass Subwoofers 44 2nd April 2006 09:25 AM
Cheap 12" woofer needed for 3way OB to play 40-150hz exipnos Multi-Way 5 7th January 2006 07:49 PM
Driver Suggestions bjackson Multi-Way 10 28th February 2005 12:23 AM
Copyright ©1999-2017 diyAudio
