Capacitors used in Crossover
Old 27th May 2006, 02:01 PM   #1
la1209 is offline la1209  Hong Kong
Default Capacitors used in Crossover
Any suggestion of capacitors that using in a clone R3.8 X-over??
I've already order some Clarity Cap SA, is it good to use in R3.8??
Thanks!
Old 27th May 2006, 03:21 PM   #2
kevinkr's Avatar
I've no experience of them in your specific x-over design, but I have used clarity cap SA grade as replacements in the x-overs of my old JBL Rhodes C-37 and they sound just fine.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th May 2006, 03:50 PM   #3
RJ is offline RJ  United States
What's an R3.8 and what tweeter did you use?
I'm using Clarity caps with a bank of Jantzen caps as the base caps in my crossovers and I also parallel a bank of film&foil caps across the base caps. The F&F caps are a combination of .47, or .33, .22, .10 & the .01's to make up the final 1 uf.
It's the bank of F&F caps that I heard a difference in the sound. The soundstage became cleaner & clearer.
The base caps cost no more than the Solen's and it's these caps that I replace that makes the most difference.
Old 27th May 2006, 04:08 PM   #4
R3.8 is ProAc Response 3.8 clone
Tweeter: Scan Speak D2910-9700
Mid Bass: Scan Speak 18W-8531
Woofer: Scan Speak 18W-8531
Old 27th May 2006, 05:00 PM   #5
WoW! Them drivers probably deserve nice crossover components.
Here's more info on bypassing caps that I came across after I stumbled across an audible difference in caps.
http://www.humblehomemadehifi.com/Cap.html
http://www.northcreekmusic.com/Bypassing.html
http://www.htguide.com/forum/showthread.php4?t=20346
Old 28th May 2006, 06:16 AM   #6
Thanks a lot!
Since I order Duelund Graphite Resistors & Clarity Cap SA, also ERO MKP1837, according to Tony Gee's suggestion, I think the result is positive!
Beside, how about Jentzen Cross Cap??
Old 28th May 2006, 02:15 PM   #7
GM is offline GM  United States
GM's Avatar
Greets!
FYI: http://members.aol.com/sbench102/caps.html
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Capacitors used in CrossoverHide this!Advertise here!
Pre-bias capacitors in crossover svensken Multi-Way 22 19th July 2013 02:02 PM
BOZ Preamplifier , Solen used capacitors for crossover gaborbela Swap Meet 6 4th February 2009 09:18 PM
capacitors in parallel in a crossover Jonasa Multi-Way 3 6th January 2008 09:24 AM
Tantalum Capacitors in the Crossover? rhythmdiy Multi-Way 2 29th October 2007 09:10 PM
Passive crossover capacitors ir33t Parts 0 20th March 2003 02:15 AM
