Old 26th May 2006, 11:13 AM   #1
Default Eros by Wayne Jaeschke opinions
I'm after opinions on these speakers especially in comparison
to the Ariels by Lyn Olson and the "Thor".......
Trying to decide which to build - having not actually heard any of them.
Andrew
Old 26th May 2006, 11:16 AM   #2
Oops...for the URL for the Eros...
http://www.speakerbuilder.net/web_fi...ct/erosmk2.htm
Old 26th May 2006, 01:58 PM   #3
One factor to consider is :
(The Eros) is tailored to the impedance requirements of
low-powered tube amps, such as single-ended triodes.
What this means in real English is it has been tweaked to sound
"right" or "best" with an amplifier with significant source impedance.
/sreten.
Old 26th May 2006, 03:27 PM   #4
Disagree. This is an inference that is incorrect.
He means to say that the speaker is an easy load for any amp, even low powered SET amps...
(Closer inspection reveals that his design goals were to revise the crossover such that the speaker's impedance doesn't drop too low below 4 ohms, that doesn't have wild swings in impedance phase angle, AND is remains relatively high in sensitivity)
Old 26th May 2006, 04:47 PM   #5
Disagree.
Its not an inference to assume source impedance affects crossover Q's.
/sreten.
Old 26th May 2006, 05:04 PM   #6
infinia is offline infinia  United States
infinia's Avatar
Quote from designer
"My only strong recommendation is to use the lowest gauge foil inductors you can afford (preferably 12 awg copper or better). I tried this design with regular air-core inductors and they seem to veil the upper midrange slightly"
This suggests to me that low feedback ie lower damping factor amps can impact the desired sonic qualities. Tube amps aren't known for lowest output impedances. So probably not best suited for toobs.
Looking at the final impedance chart suggests highish F3, so maybe bass shy for some.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Wayne Kerr B424 help Clif225 Everything Else 1 10th September 2006 01:50 PM
6 Wayne J Dayton Home Theater Speaker kits (woofers, tweeters, xovers) wigginjs Swap Meet 0 27th February 2006 01:49 AM
Wayne J's Low Cost Dayton 5.1's as Dipoles wigginjs Multi-Way 4 10th May 2004 01:38 PM
Wayne, Nelson and Karen: New Pearl was born last night dshoaf Pass Labs 0 3rd January 2004 04:54 PM
Wayne Volume Control patent official yet mlloyd1 Pass Labs 4 6th December 2002 11:49 PM
Page generated in 0.08791 seconds (75.16% PHP - 24.84% MySQL) with 10 queries
