I just read a thread about Glass enclosures, And I dont want to hijack that one so.. Ill start my own
Would it be alright to build a front baffle for a speaker out of plexiglass ? |
#2 |
Well, Ok, I'll allow it.
Sure, why not? Magnat did an all-plexiglass enclosure years ago that was quite beautiful. As mentioned in that thread, the issues with plexiglass is that it is soft (compared to glass) and easy to scratch. A heck of a lot easier to work with compared to glass tho... Mark
Breaking speed records - http://www.mach5audio.com |
#3 |
add less prone to breaking. My wife wants me to replace drab baltic birch open baffles with 3form ecoresion panels. (http://www.3-form.com/ ). Note a 4' x 8' x 3/4" sheet can cost 2k. I haven't inquired but I think you can have them cut, machined, and even bent to your specifications (at a price of course).
#4 |
You need a thick plexiglass , which is very expensive.Try to compare how thick plexiglass is required to be as rigid as 18mm plywood , for example. |
#5 |
A long time ago, I bought a pair of plexiglass panels and mounted 4" Phillips full-range drivers into the middle of the panels. A friend liked them so much, he bought them. That project sure paid for itself!
#6 |
PS: The panels I used were no more than 1/4" thick, maybe around 2 by 3 Ft in size. It was smoke collored and freestanding on wood blocks. Just open panels with a single driver near the middle. Not bassy of course, but sounded fine! If resonances were in the panel, it was not very obvious. I think I paid less than 100 for the pair of panels back then.
#7 |
Ohh... I feel a project coming on...
Mark
#8 |
If anyone on the westcoast wants to try something like this *cough*Cal*cough* (
(double check the addy, they may have moved) |
| Building Marshall Plexi | zxx123 | Tubes / Valves | 1 | 19th June 2004 03:01 PM |
| Building a Marshall Plexi | edsmith | Tubes / Valves | 10 | 18th May 2004 05:38 AM |
| 50watt Plexi Again | edsmith | Tubes / Valves | 2 | 23rd March 2004 07:14 PM |
| Plexi | WCC_Burnout | Multi-Way | 7 | 24th February 2003 05:22 PM |
| Page generated in 0.10505 seconds (73.72% PHP - 26.28% MySQL) with 10 queries |
