Old 26th November 2002, 01:39 AM   #1
Default tweeters interchangeable?
Hey guys.
I'm currently in the process of getting together everything I need to make my first set of speakers. Just one problem (so far...). I'm building them based on a design found on the internet (www.audioreview.com/learncrx.aspx), and the problem is that I can't find the peerless tweeters (model: 812687) the design says to use for any price anywhere around where I live. I can easily, however, obtain the peerless model: 811827 tweeter. My question is, can I just use the later instead of the former and still get decent results? Does the overall design and result depend that critically on which tweeter is used? I've looked at the T/S parameters for each, and they do vary significantly in some parameter values, but I'm not sure of how badly each would affect the end product.
Craig.
Old 26th November 2002, 02:10 AM   #2
SY's Avatar
T/S parameters aren't particularly relevant for a tweeter. If the impedance curve, sensitivity, and frequency response are similar, you can probably substitute- at some performance cost. If not...
Have you tried contacting Peerless directly to get pointed toward a source for the correct tweeter?
Old 26th November 2002, 04:38 AM   #3
thanks. Yeah, the important specs for the tweeter seem to be in order. Tried to contact peerless, and the only distributor in australia is wes components, and they don't carry it. but thanks again!
craig.
Old 2nd December 2002, 07:16 PM   #4
I don't know if you want to go to the trouble of ordering from overseas, but that tweeter is available from both Speaker City and Parts Express.
Old 3rd December 2002, 05:50 AM   #5
Yeah, thanks. I saw it, but it seems like a bit of trouble for various reasons, so I think I'll try the other tweeter, and if the results aren't what I'm looking for, I'll consider the matter further!
Old 3rd December 2002, 06:38 AM   #6
The Peerless 810665 looks like it might be a little closer to the 812687. Can you get it?
Old 3rd December 2002, 07:23 AM   #7
Not sure. I'll have to give the Aus. distributor a call, but yeah, I'll look into it. Thanks!
12AT7 vs 12AU7 (interchangeable?) jn2630 Tubes / Valves 5 12th January 2008 05:34 AM
:Help: Are these transistors interchangeable? tarnationsauce Solid State 22 14th August 2007 07:22 PM
Transistor variants - interchangeable? tigger01 Parts 22 6th July 2007 10:07 PM
PD2150 impedance, are 4ohm and 8ohm re-cones interchangeable? Puggie Subwoofers 2 28th March 2006 04:24 PM
Tweeters Vivek Multi-Way 13 23rd October 2001 11:06 AM
Page generated in 0.09007 seconds (75.36% PHP - 24.64% MySQL) with 10 queries
