Impedance Chart?
Hey guys i'm trying to figure out how to read an impedance chart that has no ohm markings. For example this one.
I've attached an image of the plot of an audax Audax HP100M0.
I need to trace the impedance plot into passive crossover designer but i can't mark low ohm high ohm with out knowing what each bar represents in ohms. The nominal impedance is 6 ohms.
Thank you and any input is appreciated.
I can't be specific but manufacturers impedance plots I have used typically are logarithmic. Typically doubling each division (2,4,8,16). The resonance peak looks a little rounded rather than pointed and this suggests this plot might be logarithmic too.
BTW, your box will change the bottom end of this plot.
Also, there is no impedance phase data which will be necessary for building a passive crossover.
