.00 upgrade to an old pair of KLH 911b's
Old 21st May 2006, 07:06 PM   #1
type is offline type  United States
Default $8.00 upgrade to an old pair of KLH 911b's
I have an old pair of KLH 911b bookshelf speakers that, to me, sound pretty good. They're a sealed 2 way design and are well stuffed by the manufacturer. I like the bass and midrange but the highs just aren't there. I'm considering replacing their cheap poly tweeters with something a little better.
The HI-VI TN25 FABRIC DOME TWEETER is only $8.28 at parts-express and is a perfect fit into the existing cutout. Do you think this will be a noticable improvement?
http://www.partsexpress.com/pe/showd...number=297-408
Old 22nd May 2006, 12:09 AM   #2
blake_mooney is offline blake_mooney  United States
blake_mooney's Avatar
Send a message via AIM to blake_mooney Send a message via MSN to blake_mooney Send a message via Yahoo to blake_mooney
Should be a noticable upgrade, KLH uses very, VERY cheap parts for their speakers.
"Community driven video lab" http://lumenlab.com
Old 22nd May 2006, 01:59 AM   #3
bobo1on1 is offline bobo1on1  Netherlands
Modern plastic tweeters sound really bad to me while fabric tweeters sound great. Cheap woofers seem to sound fine though.
Old 22nd May 2006, 03:24 AM   #4
That's exactly the case. The woofers sound fine, it's the tweeter that needs refinement.
Old 23rd May 2006, 03:02 PM   #5
About a year ago I bought a surround speaker set from evidence acoustics, it was on sale, priced down from 250 euro's to 50 euro's.
The fronts sound great, it has 2 no-name woofers, a nice frabric dome tweeter and a first order 2 way filter, I'm still using them now.
However the center and surround speakers where unbelievably bad, partially of the crossover that was basically one capacitor for the tweeter, but mostly because of the incredibly bad plastic tweeter that was in there, it even had a very loud bad sounding resonance whenever the waveform clipped, which happend often when watching television.
I stopped using the center and surrounds after two weeks, I set my onkyo receiver to 4 speakers and used some 30 year old philips speakers as surrounds.
Still, 50 euro's is not bad for two nice speakers.
PS. When replacing a tweeter use one that has the same impedance, otherwised it messes up the crossover.
Also the tweeters you are planning to put in has 89 dB 1W/1m efficiency, this has to match you woofers, otherwise you could make a voltage divider for the woofer or tweeters from two resistors.
.00 upgrade to an old pair of KLH 911b'sHide this!Advertise here!
1 pair 6CG7 + 2 pair 6H30 tubes n_maher Swap Meet 4 11th March 2008 03:15 AM
41Hz AMP2 upgrade... What parts to upgrade? MotoMan_Yz400 Class D 2 6th March 2008 06:28 AM
Muse Model 2 DAC upgrade with Guido Tent DAC upgrade? jpchleapas Digital Source 1 31st January 2008 08:18 PM
FS or trade 1 pair Dynavox 6.5" woofers, 1 pair of Tweets.. JCoffey Swap Meet 4 20th September 2006 05:56 PM
Pair of Jx92s and pair of Hemp FR8 for sale LizardBrain Full Range 3 11th September 2006 04:24 AM
Copyright ©1999-2017 diyAudio
