Old 24th May 2006, 04:51 PM   #11
kevinkr's Avatar
Cross-talk between channels will only be an issue with amplifiers having source impedances that are not relatively close to zero. This shouldn't be a concern at all for any reasonable solid state amplifier, however the same is not true for a 0 fdbk single ended tube amplifier with a source impedance in the range of several ohms.
www.kta-hifi.net
Old 24th May 2006, 10:55 PM   #12
the thread originator wanted to ADD a mono monitor to an existing stereo set up without adding an extra channel of amplification.
On the crosstalk problem (or non problem), if the quiet channel has near zero output impedance, are you saying that the output will absorb the signal crossing from the active channel and thus prevent the quiet speaker receiving a part of the active signal?
regards Andrew T.
Old 25th May 2006, 09:44 AM   #13
Did it Himself
richie00boy's Avatar
Yes Andrew that is how output impedance controls loudspeakers - I'm sure you are aware of damping factor.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Mono to stereo input wiring question Keskin Class D 8 1st March 2009 11:33 AM
Xlr Stereo To Xlr Mono jaya000 Solid State 4 9th February 2009 02:24 AM
Stereo/Mono 4x12" Marshall cabinet wiring tone1963 Instruments and Amps 5 5th January 2008 09:17 AM
RCA: Stereo to Mono? silentblackhat Car Audio 13 20th October 2007 04:06 AM
stereo/mono WIRING CG_25 Instruments and Amps 23 13th August 2007 08:09 PM
Page generated in 0.06899 seconds (68.06% PHP - 31.94% MySQL) with 10 queries
