Old 20th May 2006, 12:55 PM   #1
Default tmm question
in a tmm configuration(5.5" woofer) does the fact that the second woofer is 5.5" or more from the tweeter have any negative effects
thanks
Old 20th May 2006, 01:18 PM   #2
Zaph is offline Zaph  United States
Zaph's Avatar
You didn't mention if this is a 2-way or 2.5-way design.
2-way TMM designs are generally a bad idea because the effective driver center of the woofers is further away from the tweeter, causing a very narrow vertical listening window, among other power response issues.
2.5-way TMM designs don't have this issue, other than a mild downward tilt of the lobe in the lower midrange.
The optimum configuration is actually a 2.5-way MTM, which eliminates all problems related to using two woofers with one tweeter.
-Zaph|Audio-
Old 20th May 2006, 01:20 PM   #3
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
In a TMM, the second woofer is better used as a 0.5 woofer to assist in baffle step and reinforce the bass. If you want to use both woofers covering the same frequencies, then I believe a MTM is the preferred method.
No longer DIY active
Old 20th May 2006, 01:33 PM   #4
Zaph's Avatar
I beat you by two minutes.
-Zaph|Audio-
Old 20th May 2006, 01:36 PM   #5
that answers that! thanks guys!
Old 20th May 2006, 01:40 PM   #6
rabbitz's Avatar
Hey.... when did you sneak in? I must learn to type faster.
Allowing for Oz time I must be hours ahead.
Old 20th May 2006, 03:09 PM   #7
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
Zaph,
How would a 2.5 MTM work? Would you roll-off the top woofer sooner then the bottom woofer (so you end up with a TM at higher freq.)?
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.08224 seconds (74.72% PHP - 25.28% MySQL) with 10 queries
