Anyone designed a loudpseaker with a full range driver and a bass driver?
I have 2 pairs of nice 6.5" midbasses, where the bass response is great but the midrange is so so, thought about using a popular full range like the CSS FR125S or fostex equivalent, with a filter in the lower bass region. Any suggestions?? Cheers, ~Andrew |
#2 |
You can take a look at the "BassZilla" here -
http://store.hifiauthority.com/olsherkits.html It of course can't use your 6.5s, but that's the one design I could think of offhand. BTW - have you tried posting in the fullrange forum? I'm sure you'll find people there who have built with subs, supertweeters, etc.
Soft Dome |
#3 |
those look interesting... I live in a small house, and there's always an emphasis on full range drivers being used in applications aimed at very large rooms, I'm satisfied with output from 20-28 litre enclosures, the bass drivers I have can be tuned down to 35hz, which is great I think. I figured the full range forum was for designs using one driver only, anything requiring a crossover or drivers playing different frequencies would be covered in loudspeakers!
I like the idea of using a fullrange unit with a bass driver, where there is a lot of stress put on the unit. That way you can have loud clean mids and highs with one driver and the heavy bass taken care of by a dedicated unit, without the need for a subwoofer. |
#4 |
By all means go ahead and design some bass units with your 6.5s - sounds like an interesting project. Maybe go "semi-active" by using some subwoofer amps to drive them, and using the amps' adjustable crossover to seemlessly integrate with the fullrangers. Just a thought.
I'd still check out the Fullrange forum - yes they use fullrange drivers there but not exclusively - lots of speaker designs INCORPORATE fullrange drivers as midranges or wideranges, then supplement whatever weak areas those drivers have, as you plan to do. I think if you repost your original query there you might be pleasantly surprised at the response. Lots of people on this site prowl more than one category - you'll see the same people on fullrange as well as loudspeakers, etc. And if you have a digital cam we ALWAYS want to see photos of projects. Good luck and keep us informed.
Soft Dome |
| full range and bass | bull041161 | Full Range | 17 | 1st July 2009 04:32 PM |
| Best full range designs suited to rock music? | wixy | Full Range | 12 | 2nd December 2007 03:49 AM |
| Full Range Dipole Designs - Any Advice? | Forster | Full Range | 5 | 9th January 2007 01:13 PM |
| Any 2 or 3 way designs that sound like a full range | regal | Multi-Way | 1 | 12th August 2005 10:30 PM |
| Page generated in 0.07918 seconds (67.99% PHP - 32.01% MySQL) with 10 queries |
