Old 18th May 2006, 09:52 PM   #1
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Default TQWT (again?) help
Anyone willing to solve this case ?
I need measures for tall (not folded) TQWT
I know that overall dimensions are not critical,but vent certainly is;
This is what I measure ,using procedure from JBL Speaker Shop.
Unfortunately,I don't have way to measure Xmax,if needed
TIA
old Scan Speak Alnico driver
21W38
Fs=64Hz
Qms=3.054
Qmc=3.308
vas=20.6L
Cms=0.2508mm/N
Mms=24.66gr
Rms=3.246kg/s
Sd=240.52cm^2
Qes=1.155
Re=3.7E
Bl=5.6537
Qts=0.83
Eff=0.4509%
Spl=88.74db
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 30th May 2006, 07:49 AM   #2
hlj is offline hlj  United Kingdom
Hi seems only live tqwt thread, I am in the process of building a peer of ml-tqwt's, and I was wondering if it makes any difference to mount the driver on the opposite side to the port, i.e. port on back of enclosure?
Old 30th May 2006, 03:48 PM   #3
GM is offline GM  United States
GM's Avatar
Default Re: TQWT (again?) help
Greets!
Have you tried MJK's Classic TL designer? It does a pretty good job, certainly far better than any of the old rules-of-thumb that folks have traditionally used: http://www.quarter-wave.com/Theory/Alignment_Tables.pdf They can be a little confusing if you're math challenged, so there's some insight in this recent thread if you need it: please help with MJK's alignment tables
WRT Xmax, I don't know about the SS drivers, but with underhung AlNiCo motors, the highest I've ever seen published is on a 15" at ~4.6 mm, so being a ~8", I imagine it's <3 mm.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 30th May 2006, 03:52 PM   #4
GM's Avatar
Greets!
So? Why 'hijack' his thread instead of starting your own? Anyway, it matters, but normally in a positive way to vent out the rear, with best being downfiring, to help attenuate undesirable higher order vent output.
GM
Old 30th May 2006, 05:40 PM   #5
Thanks GM
Sorry mistook as a general help thread for tqwt info. i will also check out the link you provided.
Vas and TQWT mahleriana Full Range 12 28th November 2007 12:38 PM
tqwt kenneth Multi-Way 1 2nd October 2006 08:51 PM
What is the Q of a (ML)-TQWT, (ML)-TML, etc Elam Full Range 0 18th June 2005 08:56 AM
Looking for help with a TQWT box xbofmnx Multi-Way 8 14th April 2004 08:37 PM
Ml Tqwt masummo Multi-Way 2 12th January 2004 06:54 AM
Page generated in 0.09619 seconds (71.59% PHP - 28.41% MySQL) with 10 queries
