Old 16th May 2006, 04:18 PM   #1
andy2 is offline andy2  United States
Default When will lacquer smell go away?
After putting on lacquer finish, there is some strong smell that still stays around for a few weeks now. Will they eventually go away?
Old 16th May 2006, 06:43 PM   #2
sdclc126's Avatar
What kind did you use? If it is solvent-based it simply may be a high-solvent content formula that takes a long time to cure fully.
Did you happen to use any solvent-based adhesives in your construction? It's possible the lacquer may have come in contact with the adhesive and released some nasties from it also, but that's a long shot.
I think you'll just have to be patient - I've never heard of any lacquer, varnish etc. that doesn't stop smelling after awhile.
Soft Dome
Old 16th May 2006, 07:16 PM   #3
Stocker is offline Stocker  United States
I concur. Some time in a hot garage may also help, if your garage heats more than the rest of your home, stick them out there a while, with the door open a little to let vapors out... beware explosive vapors!
Jesus loves you.
Old 16th May 2006, 08:16 PM   #4
chrisb is offline chrisb  Canada
It's mostly about air flow - put them near an open window with a fan blowing out.
Total curing could take several weeks to a months
Old 17th May 2006, 01:10 AM   #5
I am using Deft lacquer then a final layer of Minwax polish.
Here are a couple of pics. They look kind of decent:
http://s47.photobucket.com/albums/f1...urrent=TJL.jpg
http://s47.photobucket.com/albums/f1...t=TJL_rear.jpg
Anyone used Beeswax? Is it better than Minwax stuffs?
Old 17th May 2006, 01:23 AM   #6
BobEllis's Avatar
Nice looking speakers.
Beeswax is very soft - it doesn't make for a durable or particularly glossy finish. Harder waxes will make a better gloss, but stuff like Butcher's Wax needs machine buffing. Try an automotive wax if you want a decent compromise between gloss and hand buffability.
How do I get rid of that rubber smell? grimberg Everything Else 0 31st July 2008 09:27 PM
What lacquer type that does not smell andy2 Multi-Way 6 27th May 2007 04:28 AM
Do all lacquer smell the same? andy2 Multi-Way 25 3rd June 2006 12:45 PM
Page generated in 0.08939 seconds (75.38% PHP - 24.62% MySQL) with 10 queries
