spica tc-60
diyAudio Chief Moderator
Joined 2002
You will need a calibrated measurement system capable of minimum phase. Also a loudspeaker management processor of the calibre of BSS and XTA. Totally configurable and not textbook filter equiped. Good luck if you ever try it. Still you will get a different speaker. There is resonance and damping finely judged between the crossover and the total transfer function in the Spicas.
