First off, what is the sensitivity gain when using multiple identical woofers? Is it +3 or +6 when going from 1 to 2? Beyond that, what is the rule for increased output with increasing # of drivers?
Second, when designing a crossover, what impedence are you looking out when creating the lowpass filter for multiple woofers that you intend to share the same branch of the crossover? Say I've got 2 8ohm woofers . . . am I designing an 8ohm crossover, or a 4ohm crossover? Thanks, Kensai |
#2 |
For the two woofers in parallel, the gain is +6 dB. E^2 is constant, so E^2/R goes to e^/.5R for double the power, and 3 dB gain. The two woofers at low frequencies are much smaller than one wavelength, and are operating in the region where coupling to the air is inefficient. Doubling the area by using two speakers is good for an additional 3dB.
With the speakers in parallel, a 4 ohm crossover, for that branch. Seriesing speakers gets a bit messy, especially if the resonant frequencies are not identical. |
| Multi-Channel PSU design | vossie | Chip Amps | 5 | 2nd September 2004 06:28 AM |
| VBIGC multi-amping / PGA2310 questions | sergiusz | Chip Amps | 4 | 4th June 2004 01:25 PM |
| Sub woofer questions | Matttcattt | Subwoofers | 90 | 17th March 2004 11:49 PM |
| Multi purpose multi channel gainclone PCB: Team project - group buy | rick57 | Chip Amps | 14 | 29th March 2003 05:54 PM |
| Page generated in 0.07198 seconds (67.38% PHP - 32.62% MySQL) with 10 queries |
